Herb's rosmery cuttings
Discussion in 'Cooking in your Motorhome' started by Wildbill, Jul 16, 2016.
  1. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,248
    12,925
    somewhere
    I have Ben given a huge rosmery cuting .
    I have poted it with rooting compound will it take.
    I have taken smaller cuttings to and planted them.
    We also got sume other herbs origano parsley sage mint thyme , Basil
    Any advise on keeping them alive as a do have a black thumb
    Bill
  2. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,787
    12,008
    Plympton, Devon
    You need very small cuttings, say two or at most three inches long and ones which have a green, soft stem not a hard woody stem. Put them in well drained compost, planting them around the rim of a clay pot if you have one, then put the whole pot in a plastic bag after watering them and allowing to drain.
    If you have woody cutting stick them in the ground outside and don't let them dry out. These may take a year to get going
    • Informative Informative x 2
  3. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,248
    12,925
    somewhere
    IMG_20160716_151420266_HDR.jpg I have planted the big one in a barrel in compost
    And sum of the small cuttings in a clay pot with routing powder.
    We buy a lot of herbs
    If the rosmery dose not take we will buy a established one noting lost if it snuffs it
    See pick
    Bill
    • Like Like x 1
  4. Camdoon
    Camdoon Funster Life Member
    Sep 22, 2012
    220
    474
    UK
    Planted a rosemary bush ten years ago, filling in at the end of a small hedge. Thrives and supplies us with copious amounts. Trimmed to keep tidy occasionally but no other maintenance required.
    • Informative Informative x 1
  5. Madeinengland
    Madeinengland Funster
    Aug 21, 2015
    721
    710
    Norfolk
    Rosemary cuttings root really well in a jam jar of water. Ready to plant once roots have sprouted. :)
    • Like Like x 1
  6. rangitira
    rangitira Funster
    Jun 30, 2010
    6,387
    13,205
    Cornwall
    Good tip if you want to take cuttings, and of course don't want to have acres of pots strewn around the section, or! of course if tou hav'nt the room in your G/House whatever!
    Take some of the fabric you use for weed control, it's got to be minimum of 12 inches 300mm wide, I generally use 18 INCHES 450MM WIDE, and as long as you wish, however space or lack of space is the reason for this type of stuff! .
    If you can get Spagmun Moss really really good, if however you can't, no worries! a good multi grade compost will do, AND PEAT based is better !
    Lay out the Cloth and put a handful of MOSS/COMPOST every hands widthin the middle of the cloth.
    Prepare your cuttings, Rooting Gel or power, and place about 150 mm /6inches apart, in the compost/moss ,How long you want the cloth or how many cuttings you wish to take is up to you , I generally stop at 1.8mtrs/6ft
    Once you have all the cuttings in situ. fold the two sides together and rollup the cuttings/ compost/moss into a tight ball, tie with string, a minimum of two places , water!
    Keep moist over winter,MOIST IS NOT SOAKING BLOODY WET!!! moist is moist!This way is not an instant shrub/bush maker it takes TIME!
    This is good way to take cuttings of Any Currants, Buddlia, Deutzia, Pliladelphus any Lavender virtually any hardwood cutting, although only the ones mentioned have I actually had success with, or even tried
    A 1.8mtr/6ft of cloth generally forms into a 6-9/150-225mm circumference ball
    Any way Happy propagation!
    PS Basil cant be propagated by cuttings only by seed
