HELP (1 Viewer)
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Just went to the van ( Autotrail Tracker ) and the vehicle battery is flat... !! I thought the Sargent 325 was supposed to balance the charge to whichever set of batteries needed it. ??
Is this what some of you mean by "Fit a B to B link" ?? I do have a C tek type charger (Aldi version ) and I can plug that in and leave it on permanently, as the van is on 'hook-up...
All advice gratefully received.. Mitch... PS.. when I go to the control panel above the hab door and turn it on, It shows full battery on both hab and veh... Ta much in advance... M.
Feb 24, 2013
13,054
101,387
Bolsover, Derbyshire
Hymer S800
not long enough
Not too sure how much help I can be other sharing your plight, I had the same last week on a CL, had to be jump started
Did you say your MH is on hook up? If so my thought is that your cab battery should be topped up by that, but might be wrong
When I flattened mine I had left an inverter plugged in to cab cigar lighter, but the controller showed 12.5V on cab battery, but as soon as I turned ignition on this dropped to 9V
However we occasionally have a starter motor issues where it just clicks, try a few more times and it always goes, this might be your problem rather than flat battery, unless you have that awful slow turn over clue!!
I will follow other replies ref B2B I think I need that fitting on mine
good luck
David
golly
2,005
69,581
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
On the control panel on our van you choose which to charge while on hook up, either vehicle or leisure. Just been out and switched mine over, usually switch to vehicle battery for a few days each month (on hook up all the time)
dogman
549
440
chepstow
Coach Built
I'm a newbie
How do you "select" which one please.
43,304
49,292
different control panels have differing methods.
earlier Swifts had a 3 position rocker switch marked with cab-off-hab
press switch to whichever needed charge.
could use the same swith to select which battery to use off hookup...or centre position would turn off all 12v power.
dogman
549
440
chepstow
Coach Built
I'm a newbie
Mine is quite different on an Autotrail 840SE, all toggle switch and digital read outs.:Doh:
golly
2,005
69,581
HYMERCAR PVC
since August 2009
Just been out and got photo, is yours anything like this.
MitchandJenny
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Since 2010
Have just gone out and switched to 'vehicle' on the panel above the Hab door and just to play safe, left the power switch on the same panel, in the 'on' position, although I doubt that that will be necessary.. Will see what tomorrow brings !!!! Ta folks !! Mitch..
dogman
549
440
chepstow
Coach Built
I'm a newbie
I assumed that it had to be "selected" rather than just have it showing in the window?
MikeD
3,936
3,697
London
IH PVC
Since 2012
Battery charging
My Autotracker switches automatically between the leisure and vehicle batteries.
Often the selection switch Top RH out of the four just lights up by its self.
We leave our Tracker on the drive and it is permenently plugged in.
Hope this helps. :thumb::thumb:
dogman
549
440
chepstow
Coach Built
I'm a newbie
In that case the button with the battery icon switches the charge between batteries. As I say I switch it to the vehicle battery for a couple of days each month, if I haven't had it out for a run.
Many thanks, I'll switch it over tomorrow and see how I get on, this forum is a great tool.
Thanks to all who have posted.
Cal
MitchandJenny
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Since 2010
Battery charging on hook-up.
Very many thanks to you all for the advice, I went out today and it started without a problem.
MIKE D, You said your tracker switches automatically between the two ??? I wonder why ours doesn't ?? I might send Sargent an Email and ask them whats what..!! Mitch..
