Help
Discussion in 'Photography' started by tyrangie1, Feb 15, 2010.
  1. tyrangie1
    tyrangie1 Read Only Funster
    Oct 6, 2008
    85
    Isle of Wight
    Hi all
    :helpsos: Can anyone give me some advice about my digital camera.
    It has always worked fine but I don't know if I have accidently changed some settings as now it works fine indoors and it will take a small movie indoors but no matter what the weather when i try to take any picture outdoors you can see a little of the subject i am taking but the picture is almost white as if there is too much light. :Doh:
    Any advice would help and many thanks in advance. :thanks2:
  2. sue1959
    sue1959 Read Only Funster
    Feb 11, 2010
    1,390
    626
    Ireland
    What type is it?
  3. Masman
    Masman Funster
    Sep 25, 2009
    304
    195
    south yorkshire
    hi try checking your setting for white ballance. if set wrong this can give you the effects tha are showing. :Smile:
  4. big map
    big map Funster Life Member
    Mar 8, 2009
    2,322
    17,110
    Poole
    Hi.
    What make and model of camera is it, with this info we may be able to help you more.
    You could scroll through the camera menu and see if it gives the option to ''return to default'' or ''clear settings''.
    Mike.
  5. tyrangie1
    Oct 6, 2008
    85
    Isle of Wight
    Thanks for your replies.
    The camera is a Casio Exilim S880
    I have used the reset to original settings but it made no difference.
    I also tried to set it up using the Manual, but i will try any suggestions i get :thumb:
    Thanks again
    Angie
  6. Linda and Steph
    Linda and Steph Funster
    Jun 18, 2008
    1,362
    1,382
    Lancaster
    Sounds like you've pushed the ISO to max or opened the aperture all the way. Or, if using auto settings you might have set it to night shoot.
    As the others have said, give us the make and model and the solution will follow. :thumb:
  7. big map
    Mar 8, 2009
    2,322
    17,110
    Poole
    Not sure if this will help, but you could try removing the battery from the camera and leaving out for ten minutes or so. When you put the battery back in the camera go to the menu and restore default settings again.
    If the camera has succesfully returned to default settings you will have to reset the time and date.
    Mike.
