Help with X250 handbrake required (1 Viewer)
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
Hello, does any know how to adjust handbrake on Fiat X250 base with ALKO chassis.
Lunar Roadstar 2008.
Sep 3, 2012
7,549
26,047
Cheshire
C Class Elddis 175
8+ years
You can adjust the brake cable from under your van just before the cable split to the rear wheels there is a threaded rod with an adjusting turnbuckle on it. You van adjust the cable length here. Just note though that when the rear shoes are replaced you will need to loosen this back off.
Sep 10, 2012
2,131
3,706
worcester
Sunliving van
Do u want to adjust leaver travel or brake pad adjustment?
Leaver as above - shoes through a hole in the disk when the wheel is off. The center of the rear disk is a small brake drum.
Well it is on a standard X250.
Hth
Autowbars
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
On last years MOT it stated in an advisory that there was little reserve travel on the handbrake, so thought I had better give it a bit of adjustment.
By the way, it has always been CRAP, as have most of previous MHs.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Check Fiats adjustment info first. The handbrake auto-adjusts in use so all you are able to do is take up cable stretch - and if you go too far the auto-adjust can't work.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
attachment.php
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
With handbrakes you should always adjust the wheel end first. Slack off the cable a bit and with handbrake off and rear wheels removed adjust the handbrake shoes as indicated in Techno's picture above until wheel is locked then back off the adjuster till the wheel just turns freely. Once all rear wheels are adjusted you can then adjust the cable to give the required lever travel.
D.
Autowbars
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
That ALKO type adjustment is just what trailers have with ALKO brake drums.
Had not looked at them up to now, but if that is the braking system it is CRAP and frightening.
Did not realise that the ALKO chassis had that.
Must take more care when buying.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Its not Alko. They are Fiats brakes that Alko fit.
Exactly the same on a panel van
Autowbars
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
Certainly adjust as ALKO at rear of drum etc, thanks for the help.
Must get my aged body under it in the morning.
Hate paying for easy to remedy situations.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Alko make the chassis, the axle, the shock absorbers and the modified handbrake cables.
All other parts you order from the Base vehicle maker whether Fiat Peugeot or Citroen.(y)
Jan 24, 2010
2,440
4,848
Adria Twin
Ive just had to do a similar thing on my rear brakes - thanks to the last service doing a shortcut on setting the brakes - that short cut is just nipping up the nuts underneath which resulted in the need for new shoes....
You really need to do as Dave has said above and start from the wheels and do the whole procedure
Attached the instructions
It takes patience to get the rear shoes set right and you have to lift both wheels at the same time in my recent experience
  • brake adjust.pdf
2,440
4,848
Adria Twin
Thank you bungy
Your welcome(y)
The patience bit is once setting the shoes full on using the star nut inside the hub, the manual says turn back 5 turns +-1 to give the right clearance,this bit really depends on the state of the shoes and make I think. and clearance is a relative term as well. After loads of searching i found a guide that said turn back until there is some drag but the wheel will stop after 1 full free turn/spin (@dave newell lvs could probably explain better than I can :))
When re tightening the nut in the last bit - dont over do it as you can ruin the faffing about with the starnut!! I ended up borrowing a torgue spanner to do it as per the guide rather than using guess work.
Just remember that each shoe is pivoted in the middle on a metal pin and the starnut adjusts one end whilst the cable adjustment nut does the other, and its the later end which is moved by the handbrake so over doing either may not help!!
For info - I changed the pins and springs as well as the shoes (£10 from brakeparts on eBay), the original pins that hold the shoe in place was stretched because the brakes had been set wrong and were binding so putting stress on them.
Good luck with it (y) - im off to finish changing the throttle body now...8 yrs an nothing gone wrong on the van and in the last few weeks its none stop!!
Autowbars
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
Done it just over an hour with all your help
The wheel type adjustment is just like ALKO brakes on trailers.
Cable adjustment was simple as all greased up and NOT sized
Sneezed, seeeeezed, bloody auto correct!
Very little adjust needed, I think it is just as I have found on previous MHs the handbrake is CRAP
Techno
Jul 28, 2010
15,475
20,756
May 2010
I did mine 3 yrs ago and it is still passing MOT's 4250kg The brakes are fine IMHO. The shoes should not wear at all if adjusted correctly so now you are in a good position having done it right to only need to take up cable stretch.
Where my van is stored I never have the handbrake on and I'm sure that helps.
Autowbars
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
I too on site, mostly, and in storage never leave handbrake on.
On our hire trailers when in yard never have them on either.
Neither does my LANDROVER as it is a right pain to replace shoes on prop operated drum and cable.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Yup, Mine wont hold on levelling blocks without Chocking!. Even My old R-V with a Shaft brake was better than that!!
Pete
