Help with suspension (1 Viewer)
May 10, 2012
407
22,220
Portugal
Don’t own one.
Since 2006(1986 VW T25)
We were told recently that our van leans to the right. It was suggested at the time that it could be a fault with the TORSION BAR what ever that is. We are at present in Edinburgh and making a few stops (over 3 to 4 weeks) on our way to London.
Is this an urgent problem and should be seen to or can it wait. If urgent where is the best place to go to, tried National Tyres they cant lift the van.
The van is still under warranty.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
torsion bar suspension on the t2 ,s stopped in 79. as your is later it hasnt got torsion bars . could be the coil springs just getting old .
if a garage told you torsion bars best not use them to fix it .
43,302
49,289
being told it could be a torsion bar problem points to an ALKO chassis.
early ALKO had one bar per side, and you'll know if that snaps, later ones had 3 torsion bars per side and if one snaps it will ride lower.
they all run inside the axle tube so cant be seen externally
if one snaps the chances are the others wont be far behind with the excess loading on the remainder.
you need a caravan/motorhome repairer to inspect it as normal garages wont have a clue.
almost 100% certain they are not repairable so get it done under warranty soonest, as a new rear axle is in excess of £1500 plus fitting.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
mm, i look at their avatar and took it to be a vw25 .sorry i could be wrong .
Feb 27, 2011
14,710
75,770
UK
Self Build
Lunar roadstar 786 appears to be an Alco chassis.
Link Removed
They started in a T25 by a careful reading of their profile???
I thought Alco chassis so didn't advise as I am not familiar with them any more.
43,302
49,289
sorry Alan, it is an ALKO torsion bar rear axle....even if its Pug or Citroen based,
specification
THE VEHICLE
■ Base vehicle and engine type: Fiat Ducato with Al-Ko extended chassis.
