dazzer
After 3 months of toil and a lot of brain teasing I have finally completed the online course to teach me how to use Autocad 2010 :thumb: (which is by the way, quite simply the best bit of software ive ever seen but very tricky to learn oh
No doubt ive still got a hell of a lot to learn but i have the foundation to be able to finally get round to designing and building a demountable truck camper to go on the back of the Lightning to use when we go off diving in some pretty remote locations around this great nation of ours.
Having given it a lot of thought we require the following to be fitted (shoehorned!! ) into what is a very small space.
Petrol driven compressor for charging scuba tanks.
Rain water harvesting system to use any rain we get (should never run out of water again !! ) for the shower and the RV style toilet.
Reverse osmosis system to again use purified sea water for showers and toilet. (This system requires a high pressure pump to make it work but we can just use the many "empty" (for diving anyway but still have between 50-80 bar inside) tanks to pressurise the system and make it work.
A big battery bank (the 6 volt high a.h. submarine type batteries linked together) and solar charging.
We goto some pretty remote places and sometimes stay for up to 5 days and need to be totally self sufficient. When we had our RV water was always the biggest problem as we sometimes had up to 10 divers all freezing cold climbing out of the sea begging to use the RV shower to warm up and wash the saltwater off themselves hence the huge effort in being able to produce our own water for showering.oh:
What im really after is suggestions from the great and the good on here about rainwater harvesting, reverse osmosis and battery/solar charging systems for a ground up build. We need to keep weight to a minimum (obviously!!) and plan on using a void in the floor for battery storage and water tanks (as much as possible) to keep the centre of gravity as low as possible. :thumb:
Remember we need power to run all the systems on board and to also power an invertor so we can use a projector to watch Sky tv (the lads dont want to miss any football matches!!) under the awning and also to use the projector as a training aid for divers taking a diving course. A generator is the obvious choice but is something else we need to find a space and carrying capacity for and they are also bloody noisey/smelly things that we are trying to avoid.
Cost is obviously an issue but we have a reasonable budget and some very skilled people to actually build it, its the design around everything that is required that is the biggest headache and it is at this point I now find myself
All suggestions and help greatfully received as always
Thanks guys
For those not sure what im on about see photo :thumb:
Thanks guys
