Help with heating and hot water
Discussion in 'Motorhome Chat' started by Watky, May 11, 2014.
  1. Watky
    Watky
    May 11, 2014
    14
    Ilkley
    Please can anybody help.I am at screaming point.Away in Autotrail 740s in Scotland.Heating and Water have been working fine.Then yesterday it packed up, no green light on control panel tried it on hook up no yellow light.Checked fuses by door,checked fuses in PSU all ok.Everything else is working fine.Luckily we have Diesel heating but no hot water.Look forward to hearing from somebody.Thanks.
  2. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    hi Watky, welcome.
    i think youll need to provide a bit more detail on, type of heater? is it both gas and electric operation that have failed?
    good luck
  3. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    See you Nanook, did it by any chance freeze and dump the water from the hot tank?
  4. Watky
    Watky
    May 11, 2014
    14
    Ilkley
    Truma boiler Eh603.Thankyou for replying so quick.It did not dump water.It as been quiet mild so it's not frozen.I am new to posting threads and am not sure if I am doing this right.Why have I got a blue envelope on my post?
  5. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,874
    23,573
    Narrfoook
    Hi Watky and welcome to the forum :thumb:
    Blue on a thread indicates you have posted in the thread :Smile:
    Sooo, is it both electric and gas that has died a death.. ??
  6. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,698
    10,394
    Norfolk and Toftir.
    Don't know if that's the same as ours but our Truma occasionally throws a wobbly even with all the lights on, gas or electric or both, no hot water and no heating even when it's been working ok. Last time I pressed a green reset button on the top of the Truma housing although I don't think it actually moved. Worked ok after that. :Confused:
  7. Ridgeway
    Ridgeway Funster
    Mar 10, 2012
    928
    419
    Lausanne
    6 degrees is enough for the Truma safety valve to open, it doesnt need to be so cold and it could easily still reach that temp during the night, worth checking it.
  8. Watky
    Watky
    May 11, 2014
    14
    Ilkley
    Yes.Both electric and gas have a died.
  9. Jaws
    Sep 26, 2008
    18,874
    23,573
    Narrfoook
    And just to confirm ( sorry.. I am using up all your free posts but**... ) the water is coming out the taps ok ? Inc hot water taps but obviously not hot water ! )
    If it is, save a post and do not reply cos we will all know its not water related at all :thumb:
    ** you get five free posts then have to become a full member to continue posting .. Proly be the best tenner you ever spend mind you :Wink: :thumb: )
  10. Watky
    Watky
    May 11, 2014
    14
    Ilkley
    No valve not open.i have just checked that.
    Ours does not have a green button it as a red button on side.Pressed that but it doesn't seem to move when you touch it.
    Help!
  11. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,907
    10,284
    sounds somewhat like the supply has blown a fuse or the fuse on the truma control board has blown
  12. Watky
    Watky
    May 11, 2014
    14
    Ilkley
    I have a thought checked all fuses,and they are all ok.
    Could it be on the panel above the door,Would there be a fuse behind there? Sorry for sounding so vague but I am olderrrrrr lady with a disabled husband,so it's up to me to get things back on track.Thanks.
    • Like it Like it x 1
  13. TheBig1
    Nov 27, 2011
    7,907
    10,284
    ive seen a few fuse holders hidden behind the control panel. the truma control board is part of the heater
    if you are getting NO lights on the controller either on gas or ehu, which is what it sounds like, the heater/hw is not getting 12v power. ideally you need a voltmeter/multimeter to check voltages. perfectly easy diy if you know how but can be daunting otherwise
  14. Watky
    Watky
    May 11, 2014
    14
    Ilkley
    No fuses behind control panel got that off.Do not have a vault meter and if I had wouldn't know how to use it. Gosh am I stressed with this.
  15. Linda and Steph
    Linda and Steph Funster
    Jun 18, 2008
    1,373
    1,446
    Lancaster
    Where are you at the moment, there may be a funster nearby who could offer practical help.
  16. Watky
    Watky
    May 11, 2014
    14
    Ilkley
    We are at Tarbert on the Quay.Thanks But Motorhomes are a bit thin on the ground,not many about.
  17. Jaws
    Sep 26, 2008
    18,874
    23,573
    Narrfoook
    Done a bit of digging for you.. I do not think this will be a lot of help but..................
    A question has been asked elsewhere:
    And the reply ( although a different MH all remains the same for yours )
  18. TheBig1
    Nov 27, 2011
    7,907
    10,284
    sorry but without the basics like a meter it is very hard to diagnose the fault and fix it. for instance some fuses blow but still look to be good, so a visual only check wont really help.
    all i can suggest is that you find somewhere local tomorrow with a dealership or auto electrician if there is nobody local to you that can possibly help. in the meantime there is always heating water the old way (Kettle or saucepan) and cold showers. we all survived camping this way not that many years ago
  19. TheBig1
    Nov 27, 2011
    7,907
    10,284
    this is a local garage, who may be able to help
    Sharp's Garage, Churchill Quarry, Campbeltown Road, Tarbert, Argyll, PA29 6SX. Telephone: 01880 820006
    no guarantees though and being in pretty much the middle of nowhere does have disadvantages
    another option
    Bruce Harris Electrical, 12 Garval Terrace, Tarbert, Argyll, PA29 6TS. All types of electrical work undertaken: house, industrial, commercial, total control electric heating, also electric wet central heating boilers supplied and fitted. No job is too small and we have 24-hour callouts. Contact Telephone: 01880 820530, Fax: 01880 820530, Mobile: 07771648217 or email for free quotations
  20. Watky
    Watky
    May 11, 2014
    14
    Ilkley
    Thank you.I will go in the morning and see what I can make out.What a pain,yes all my flasks filled with hot water.
