help with gas (2 Viewers)
annadg
106
84
Suffolk
coach built
I'm new to it
We have had a faulty gas bottle ... Hope its that and not the connector ...
Now we are in south France and need new one but can't see red canisters anywhere
Any advice from the wise and experienced please ?
At least we have a spare
Anna & Mark
annadg
annadg
106
84
Suffolk
coach built
I'm new to it
I doubt it will be a bottle problem,what is the fault?
Basically we had smell of gas and it ran out very fast!
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
DIY test is mix up some washing up liquid and water and dribble all over joints. You'll see the bubbles if there's a leak.
If you mean UK red Calor bottles, I don't think you'll find any in France. Alternative is buy a French regulator and French bottle.
JohnM
650
179
Central Scotland
CClass
Since Feb 2009 and 40yrs c/vaning
Have you tried going round all your gas connections with a little washing up liquid and water to check for leak? i had a leak a few weeks ago on my gaslow system found a few bubbles on one of the conections a quick tifhten up done the job. Hope this info helps.
43,329
49,444
Anna & Mark
you wont find any in France....or anywhere else in Europe.
although the gas is the same the bottles are nationality specific......not the same.
as Brian said, you need a French bottle and regulator or the multi-national disposable Camping gaz bottle (very uneconomical) and regulator
Apr 9, 2013
663
373
Ayr
Newbie
Where was the smell of gas? In the gas locker or in the van? If the latter, you really shouldn't be using any more gas at all!
If it was in the gas locker, I would check your flexible hoses, regulator and tank connectors before suspecting a faulty tank. Far more likely that your system is faulty rather than the tank.
Tim
Heyupluv
3,862
1,593
France,
touring many years..42+
I agree with all what has been said ......a smell of gas get:Eeek: it checked...call at any motorhome place in France....or the DIY soapy liquid method if the motorhome shops are closed, as Wednesday and Thursday this week are French holidays.....if a smell of gas it is advisable to turn the bottles off and not use the gas......untill you have been given the all clear
If it is the bottle (which is very unlikely)....
You could buy a tail like the picture below to connect to your regulator to a french bottle..both are female nut type connectors....it would be the same tail or similar tail in the uk you would use for butane...but in France this also fits the propane and then purchase a French Propane bottle from any supermarket....just make sure the bottle will fit in your gas locker as bottle size's do vary.....
Send a PM to Dave Newel a fellow funster and lpg gas certified agent just to varify what I am saying about the butane pipe is correct.
Also if you require info on motorhome shops address's...call at a supermarket and buy a motorhome mag...(look in it first to make sure it has them inside)...at the back on most motorhome magazines is a list of agents /makes of motorhomes being sold in the departments in France...... look for the dept you are in for example...40, 64, 65, 09, 66, 34, 13, or 83....these are some of depts in the south of France it will show the agents selling the different makes of motorhomes...get the address of any and get your gas checked out:thumb:
If you are not sure what dept your are in here is a link...
http://www.google.fr/imgres?imgurl=...sH4rP0AWg3IDwBA&sqi=2&ved=0CEsQ9QEwBQ&dur=637
stcyr
1,765
1,160
Normandie
On & off, since 1966 - fulltime since 2005
We get our gas from Carrefour - 1 euro deposit and about 23 euros for 13kg. Sometimes with free regulator... :thumb:
