Help with electrics (1 Viewer)
Theresa100
16
6
Eton
Low profile
10'years
Hi there my 12 volt stopped working , it works on car switch but not van switch , was told it was unit but have traced the fuses and 30 amp fuse under cab keeps blowing and 30 app fuse on leisure battery blows, it works until I have engine running then stops , if anyone knows any caravan electrics in sl4 area that can help or anywhere else don't mind traveling if I can stay over in my van am quite desperate as have a lot of shows with no electric , I would be extremely grateful many thanks theresa::bigsmile:
TheBig1
17,630
43,272
split charge relay stuck open, so allows the van to try starting using the leisure battery. this draws more than 30amps so blows the fuse. could also of damaged the control panel etc
try replacing the split charge relay first
T
Theresa100
16
6
Eton
Low profile
10'years
You don't know anyone that could do this , I have no idea where the split charge realy is or how to change it , but thanks a million for your advice thanks theresa
TheBig1
17,630
43,272
any local auto electrician will be able to locate and change the relay in a few minutes. they are normally near the vehicle battery although not always obvious
on my van for instance there is a flap in the floor behind the drivers seat and its in there. just follow the wire from the battery
