Help with Electrics, please!
Discussion in 'The Beginner' started by Yogi, Apr 9, 2008.
  1. Yogi
    Yogi Deleted User
    Hi Folks
    just joined the site and would welcome advice for a newcomer. A few weeks ago bought a VW Transporter Conversion, converted professionally by LeisureDrive 18 months ago. They supplied no wiring diagram and a phone call for advice was little help.
    Zig Panel showed no juice from Leisure battery, which I've charged up and checked all fuses I can see...but still no juice. When on hook-up sockets and fridge work well but not lights and pump (very frustrating having to switch off mains to pump water for a cuppa!).
    Have booked into nearest caravan workshop - but they cant sort it till late May.
    I must be missing something....help!
    Yogi
  2. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hi Yogi,
    What Zig Panel do you have fitted in this van please?
    Was the Leisure battery charged by the zig unit in situ or by battery charger?
    Zig are very helpful.I requested a manual for mine and they scanned and emailed it to me.
    >>>ZIG HERE<<<
    JUST A THOUGHT. IS THERE AN IN-LINE FUSE IN THE WIRING BETWEEN THE ZIG UNIT AND THE LEISURE BATTERY?
    Get a multimeter and put it across the leisure battery.Note the voltage.Turn on the zig unit.Does the voltage rise?
  3. Digger Driver
    Digger Driver Read Only Funster
    Oct 4, 2007
    578
    Lancashire
    Sounds like you have a break somewhere in the 12 volt circuit between the battery and the Zig unit!
    If your handy with a multitester you could trace back the live wire from the battery back to the Zig to localise the fault!
    You could check all the connections too as i have seen them vibrate loose over time!
  4. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,328
    5,332
    East Sussex 01-580-881288
    Welcome to the FUN and Facts site!
    You will get plenty of FACTUAL help here, put your location is so we all know where you are.
    Regards
  5. Gonewiththewind
    Gonewiththewind Read Only Funster
    Sep 13, 2007
    854
    35
    Lancashire
    My son-in-law had a fault just the same, found a large in-line 40 amp fuse tucked down behind the battery, it had blown. All working fine now.:Rofl1:
    Don
  6. Yogi
    Yogi Deleted User
    Wow!
    Thanks so much...you folk are quick off the mark!
    1.. I'm in Aberdeenshire
    2. The Zig Unit is Marque 1 ; Car/'Van rocker switch on LHS Voltage dial in middle and 3 smaller rockers for pump, lights and Aux on RHS. I charged the battery overnight on a charger
    3. There is a 10A inline fuse, which I've changed and seems to make no difference
    4. Don't have a multimeter...yet
    Y
  7. michaelc
    michaelc Deleted User
    in answer,
    Hi, best think is to get a meter, they only cost around £6, check that you have power going to the LB and then work backwards to the zig unit. without a meter you will never get an answer to whats going wrong.
    michael
  8. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Any luck getting a meter yet.
    There was a post within the last week by Diabolo I think, pointing to a cheap deal at ALDI. >>>here<<<
    I assume then, this is your unit.:thumb:
    [​IMG]
    >>This<< suggests it is a monitoring panel only and there must be another charger somewhere.
