help with battery charge
Discussion in 'Motorhome Chat' started by maggie manley, May 23, 2016.
  1. maggie manley
    maggie manley
    May 23, 2016
    Englan
    We are currently touring in our adria matrix 680sp van the van has been up till now trouble free however we have got a problem with charging the leisure battery from the hook up and was wondering if anyone can give us some advice. When we plug in the hookup sign no longer shows and the water heater no l9nger works. It charges when the van is running so as long as we shift about every few days we can cope. The fridge and the plugs all seem to be running off of the 240 supply so can't understand what the problem may be would be grateful for some help
    Thank you
    maggie
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,322
    YO11 2BD
    Have you checked the 230v breaker in the mains fuse box ? There may be a dedicated breaker for the charger.
    There may also be a 12v fuse in the charger casing.
    Failing that, the charger may have simply packed in.
  3. StitchesnFluff
    StitchesnFluff Funster
    Oct 18, 2014
    1,218
    512
    Salisbury
    And check that the trip hasn't gone on the campsites hook up. We repeatedly used to trip the hook up on the aire at Brugge.
  4. pappajohn
    Aug 26, 2007
    29,703
    17,322
    YO11 2BD
    The OP says sockets and fridge are working on hookup.
  5. StitchesnFluff
    Oct 18, 2014
    1,218
    512
    Salisbury
    Oops, opticians next week!
    • Funny Funny x 1
  6. TerryL
    TerryL Funster
    Mar 5, 2010
    1,361
    1,338
    North East
    Most likely you've managed to knock off the (usually) separate mains switch for the charger, alongside the main consumer unit, by stuffing something in there for storage. Have a good look round that area. I've done it a couple of times and not noticed on the panel.
  7. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,772
    3,759
    Corby, Northants
    Yes! agree it's most probably a fuse or a circuit breaker. MM states both hook up sign and water heater not working. Highly unlikly these two items would fail at the same time if it was something other than a fuse/circuit breaker.
  8. maggie manley
    maggie manley
    May 23, 2016
    Englan
    Thanks guys we have checked all the fuses but will explore all of your suggestions and let you know the outcome
    Happy travelling
    maggie
  9. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    4,792
    9,000
    Lorca,Murcia,Spain
    & welcome.
