Help.... Win 95 install disk
Discussion in 'Computers' started by Wildman, Aug 23, 2015.
  1. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    Wanted a Win 95 install disk. Yes I know it is old but I have a vinyl plotter the software for which will only run on win 95 and the computer it came on refuses to boot. I have the sign software (for win 95 only) on disks (hopefully). Need to try an install on another machine to make sure it will indeed install.
    Anyone still have one in the drawer?
  2. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    775
    469
    Cornwall/France/Spain
    If you are not able to obtain a disk then Windows 95 is still available as an ISO file online to enable you to burn your own.
    • Like Like x 2
  3. golly
    golly Funster
    Aug 16, 2009
    1,143
    2,080
    Co Durham
    Have got this disc, but no product key, if its any good pm your address and I will post. IMG_20150823_140255724.jpg
    • Like Like x 2
  4. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    thanks everyone it seems I was misinformed, The computer has started to boot into windows ME, not 95 then hangs, I do have a windows me disk I think but unable to enter the bios to instruct it to load from CD rather than hard drive. I need to run a repair if possible rather than a new install as I need to preserve the settings for the Summacut D620 plotter and the sign maker software
  5. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,941
    Old advice for getting into the BIOS was to repeatedly press the appropriate function key as soon as the system unit was switched on, so as to be able to get in before the OS starts. If you don't know which function key to use then try Googling the machine name.
    • Like Like x 1
  6. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,244
    12,913
    somewhere
    that's a blast frome the past windows 95 :)
    • Like Like x 1
  7. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,543
    1,437
    West Midlands
    I've probably got 'em all 'in my drawer', let me know what you end up needing.
    Wyn
    • Like Like x 1
  8. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    well making some progress, left running it eventually says there is a registry problem and to run regscan, however command prompt is not one of the options to continue, they are I think
    1 normal
    2 safe mode
    3 step at a time etc
    I finally got into the bios and it should read a cd as 1st boot drive but ignores the ME disc I tried to boot with. As it is set up in the loft I am running up and down the damn stairs
  9. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,622
    2,132
    Scotland
    Have you tried to boot into Safe Mode?
    If you can get into there you could try running "Last Known Good Configuration" or a System Restore (assuming you had that set-up) to take you back to a good configuration.
    If not, this article MAY help?
    http://www.russharvey.bc.ca/resources/legacyrecovery.html
    or here
    http://www.tomshardware.co.uk/forum/166324-48-repair-winme
    • Like Like x 2
  10. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    update, I have no idea what is on the harddrive or if system restore was setup. It is a new to me computer.
    It now reports the windows loader file is missing or corrupt. I tried opening a command window to run chkdsk but no commands work without the windows loader just a c: prompt. Presumably there is no way to get to msdos. Safe mode encounters the same problem. I have no idea if there is a modem in it I think not so no way to port in.
  11. Gellyneck
    Jun 5, 2014
    1,622
    2,132
    Scotland
    Does the machine have a floppy disc drive? If so, you could try downloading a Windows Me boot disc and copying that to the floppy disc.
    Might give you access to Command Prompt.
    • Like Like x 1
  12. tick59
    tick59 Funster
    Dec 25, 2007
    1,247
    1,091
    Newcastle Upon Tyne
    CHUCK IT IN THE BIN ALONG WITH THE EMPTY FRAY BENTOS PIE TINS. fun!!! fun!!! fun!!!
  13. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,567
    9,994
    if you have the plotter software, I would install xp and run the programme in compatibility mode
    otherwise, as suggested use a boot disk and repair/reinstall ME from there
    if win.com is corrupt you could try to replace it from DOS but no guarantees it will work
  14. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    there is the plotter software driver disc(ME) though I believe XP drivers are available. Then there is the signlab software on 6 floppies, signlab want £300 to upgrade to XP so I'll have to source an ME system disk that includes scanreg and chkdsk. I don't think I can do that from my XP or win 7 computers as the dos utilities will be different. Ah well more messing about before I can start producing new signage.
  15. TheBig1
    Nov 27, 2011
    7,567
    9,994
    just checked online and there is a pirated version for win7 you could use
  16. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    I have full original versions of xp, win7 and probably most of the earlier ones but now find for some reason I cannot format a floppy disk let alone make a system disk. It is beginning to look like an end of the pier jobbie
  17. TheBig1
    Nov 27, 2011
    7,567
    9,994
    when i said for win7, i meant the signlab software
    • Like Like x 1
  18. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    aha many thanks trouble is they need a dongle and it is different for each version plus the desktop that has all of the required ports is only xp. can you pm me a link please be good to try at least
  19. Leftlegger
    Leftlegger Funster
    Sep 29, 2012
    418
    401
    N.somerset
    this sounds like a corrupt ntldr file and you may well need the admin password if you want to copy a good one across using the cd to boot into the recovery console.long time since I had to do it but you can create a boot floppy by formatting a floppy and using known good files 0f boot.ini ntldr.com sys.ini etc .
    To make it easy there was a boot disk site I used to use for making various dos boot disks,try this site:
    http://www.allbootdisks.com/download/me.html
    • Like Like x 1
  20. Leftlegger
    Leftlegger Funster
    Sep 29, 2012
    418
    401
    N.somerset
    • Like Like x 1
