Help Van Won't Lock
Discussion in 'Tech/Mech General' started by davidbaldam, May 19, 2015.
  1. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    3,191
    8,268
    Market Harborough
    My van a Laika Ecovip 7r on a Fiat 2.8 base won't lock on either the door locks and the central locking. Have tried opening and closing the driver and passenger doors but it will lock on the habitation door when I lock it from the inside, please help am suppose to be off Italy tomorrow.
  2. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,242
    6,906
    Spain for the winter
    Colin says - double check the obvious first, are all locking doors shut properly before trying the central locking.
    Also is there little electrical connector points down the inside of the doors?
  3. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,992
    40,249
    Is that from a key Fob...... and are any of your outside lockers hooked up to the locking/alarm system...
    I ask, because when I got mine it would not lock and the alarm would not set...... because one of the lockers doors had not been closed properly, and the sensor was not lining up..
    Other than that, sorry cannot help.
  4. lorger
    lorger Funster
    Jul 11, 2008
    6,402
    7,852
    Dumfries
    If it doesn't work using the fob have you tried the old fashion way using the key, our habitation door sometimes fails to lock with key fob or alarm fob for some reason it seems to get out of sequence. We just lock it with the key then it starts working again sometimes take 2 or 3 goes, tends to happen more when van isn't used for week or two.
  5. Armytwowheels
    Aug 10, 2012
    4,242
    6,906
    He also says that a flat battery could cause this problem. But I assume you drove it from the storage place to your house recently as you we getting ready for a trip?
  6. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    3,191
    8,268
    Market Harborough
    Have tried all the above but no luck, the habitation doesn't have a key we usually use the central locking. Have managed to start the engine. Must be one of the door sensors but have tried opening and closing the doors and the only outside locker we have but no luck, so have disconnected the battery so I can at least lock the doors, if it doesn't sort itself out, will have to find a local Fiat garage first thing in the morning, bloody Sod's law. :unsure:
  7. Armytwowheels
    Aug 10, 2012
    4,242
    6,906
    Dave try giving Seniors down Riverside as call. Some of their hire vans are Fiats so they should know your base vehicle pretty well. Saves you having to go out of town to get it resolved. They would probably see you first thing if you explain about the ferry booking.
  8. nomadic
    nomadic Funster
    Sep 27, 2007
    689
    187
    Shropshire based
    Had this problem once, replaced the fob battery, and all worked well after that.
    Hope this pointer helps.
  9. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    3,191
    8,268
    Market Harborough
    Good idea about Seniors will be on their door step at 08.00 Don't think it's the fob battery as the doors won't lock with the keys either.
  10. EssexBoy
    EssexBoy Funster
    Feb 5, 2009
    340
    238
    South Essex
    I don't suppose your Laika is like mine, whereby the central locking is part of the alarm system, rather than the fiat cab system, is it?
    Do you have a lock/unlock button on the dash near the radio?
    Mine doesn't have the dash button, so I worked out the Sikura alarm controls the CL, and had gone kaput. I replaced the CL with one of those £10 ones off eBay and it's great replacement
  11. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    3,191
    8,268
    Market Harborough
    bump
  12. Armytwowheels
    Aug 10, 2012
    4,242
    6,906
    Oh dear, still not working then I take it? Hope you get it sorted in the morning.
  13. EssexBoy
    EssexBoy Funster
    Feb 5, 2009
    340
    238
    South Essex
    Sorry... The point of my posting was to aid diagnosis in that if you have the same setup as me, then it sounds like the alarm is kaput and a reset (or disconnect) might allow you to get control of the locks back
    Steve
  14. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    3,191
    8,268
    Market Harborough
    Thanks for the replies have decided to go on holiday and when I need to lock the van will disconnect the van battery then I can at least lock the doors with the key if I have to leave it, like I said once in the van we can lock all the doors with the habitat Central locking system. Might ring our breakdown people once we get somewhere were we are stopping for a few days and see what they say.
    • Like it Like it x 1
  15. Bertie Bassett
    Bertie Bassett Read Only Funster
    Jul 25, 2014
    2,743
    8,717
    Hope it gets sorted at some stage and sorry I can't help despite once having a Laika. Have a good break.(y)
  16. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    3,191
    8,268
    Market Harborough
    Finally got this problem sorted, it was the wiring loom between the habitation door and the body of the van, over the years it had caught in the door frame and become brittle. Garage replaced some of the wires and jobs a good un. Phew. (y)
    • Like it Like it x 3
