Help, Urgent (1 Viewer)
Dec 20, 2010
1,646
2,961
birmingham
kon-tiki 669. mazda bongo
since2011
I orders a Swift Kon-tiki from Lodams on the 15th October 2014. Delivery date 10th July 2015. I had a call at 1806 this evening 9thJuly saying it is the wrong engine size. I orderd a 150bhp engine have have been told that the van is a 180bhp enine. As I am due to collect the van tommorow,10th July. This will afecect my insureance. Th questin is what is the different fual comsumsumtion. IE 2.3 130bhp v 18o bhp. Thanks in advance.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Question. Are you getting the uprated engine at the same price as the original you ordered?? If so, sod the insurance and fuel, (negligible), your getting quite a few bobs worth for nowt.(y)
If, on the other hand, they want to charge you.....................................:(
9
9526
The fuel consumption figures are very similar for the 2.3 and the 3.0 litre engines.
I assume you are not being charged extra (the 3.0 is normally about 2k extra) and in the circumstances I wouldn't be too upset.
edgy
389
475
bolton lancs
lo line
"I,m a newbie
You will be better off with the bigger engine. More likely to get better MPG and the engine will not be working as hard and will last a lot longer. The 3.0 litre engine is from the Iveco range and is bullet proof .
Nov 6, 2013
3,201
228,866
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
If it's not costing any extra (and it shouldn't) fuel consumption is comparable, if not better, and it is a better drive. Obviously, you should inform the insurance but I will be surprised it it makes much difference. RESULT (y)(y)
Jan 10, 2013
5,958
7,354
Near Uttoxeter and Crete
Warwick XL PVC
Still trucking and learning
We get better fuel consumption on our current van which is a 3 L than we did on our last van which was 2.3 L. Both are the same weight. Definitely would go for the bigger engine as long as no extra cost involved.
Chris
21,044
277,993
None
10 years
Don't forget the bigger engine will slightly affect your available payload( I think)
DanielFord
3,020
3,086
If it's the tag axle Kon Tiki then the 2.8 engine is a better choice anyway, so I have to go along with everyone else, if you are getting it for free then you are quids in! :D
SandraL
1,373
985
Somerset
Hymer b694sl
There will be a weight difference, I think its 50kg extra for the 3litre engine, and if supplied on the heavy chassis instead of the light another 50kg. Not sure of your vehicle weight but if plated at 3500kg this will significantly affect payload.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
He's right you know, just looked up the specs, the 180bhp engine is 3.0
Yes it is still the Iveco 3 litre motor.
180 MultiJet Power Euro 5+
The most powerful 4 cylinder engine in the range, offering the highest performance in its category. Flexibility, driving comfort, productivity and noiseless running, with enough power for all uses
Displacement: 2999 cm3
Max. power: 177 HP/130 kW at 3500 rpm
Max. torque: 400 Nm at 1400 rpm
  • Electronically controlled Common Rail MultiJet direct injection with variable geometry turbocharger and intercooler.
  • Pistons with cooling channel for higher torque levels.
  • Low emissions: system with EGR (Exhaust Gas Recirculation) valve for partial recirculation of exhaust gases.
  • 6-speed manual gearbox.
  • Also available with Comfort-Matic robotised gearbox.
  • Scheduled servicing every 48000 km.
Top speed: 102 – 106 MPH (165-171 km/h)*
NEDC consumption: 31.7 – 36.7 MPG (7.7-8.9 l/100 km)*
CO2 emissions: 203-236 g/km*
*depending on model and version
