Help....Thetford C260 jammed
Discussion in 'Motorhome Chat' started by chrisinplymouth, May 28, 2016.
  1. chrisinplymouth
    chrisinplymouth Funster
    Aug 11, 2013
    113
    57
    Plymouth UK
    image.jpeg hi ... This morning opened the blade by moving lever to the right, but when I have tried to close the blade the operating lever is jammed.
    I emptied the cassette yesterday and had used it several times since with no problem. I tried to remove the cassette to get a better look but of course this won't come out unless the blade is closed.
    Can anybody suggest a way forward?
    Kind regards
    Chris
  2. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,879
    6,807
    West Sussex
    A big hammer:D
    As the blade is open you should be able get your hand inside and have a fiddle hopefully you will find some bog paper jamming the mechanism. Once you get the cassette out take the mechanism out and give it a good clean. It comes out by rotating the top of the housing about a quarter of a turn, it will be very tight.
    • Like it Like it x 1
  3. chrisinplymouth
    Aug 11, 2013
    113
    57
    Plymouth UK
    Cheers Lenny.....will try tomorrow ....wish I had taken a better look at how the lever connects to the cassette when I had It out!
  4. scotjimland
    Jul 25, 2007
    28,984
    25,680
    • Like it Like it x 2
    • Thanks Thanks x 2
  5. chrisinplymouth
    Aug 11, 2013
    113
    57
    Plymouth UK
    Thanks Jim
    • Thanks Thanks x 1
  6. chrisinplymouth
    Aug 11, 2013
    113
    57
    Plymouth UK
    All fixed. In now know a lot more about how they work. I should have had a good look at it BEFORE it went wrong. So basically wiggled the cassette wiggled the lever wiggled the cassette again and it closed. Now taken apart , throughly cleaned and lubed with silicon. All good. The videos on the thetford site were really helpful.
