HELP solar panel controller burnt out. (1 Viewer)
Jan 27, 2014
2,073
4,355
mid wales
carthago chic i51.
Hi today we fitted a solar panel all ok until connected to the controller
Leisure battery then engine battery
control panel sizzled then smoke
all wiring correct and terminals etc
checked why would this happen
baird 100 w kit . Please can someone
advise .thank you.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
If you are 100% certain that you had made the connections in the correct order with the correct polarity then you should contact the seller
Techno
Jul 28, 2010
15,475
20,756
May 2010
Have you any information to share about the controller ?
Beacons
Jan 27, 2014
2,073
4,355
mid wales
carthago chic i51.
Hi mike took controller apart
its a duo battery sent baird 100w kit no make visabl
common yellow fronted with a red stripe poor quality we
think circuit board melted.
thanks
Techno
Jul 28, 2010
15,475
20,756
May 2010
Presumably you bought from trueshopping? I found they are not unreasonable to deal with. I would expect them to offer you a suitable discount equal to the rubbish regulator. It will be interesting to see what they value it at
Techno
Jul 28, 2010
15,475
20,756
May 2010
Or perhaps these? I suspect they are related
Broken Link Removed
Beacons
Jan 27, 2014
2,073
4,355
mid wales
carthago chic i51.
There is a 20 amp controller available would this be suitable please we will contact them monday .
Beacons
Jan 27, 2014
2,073
4,355
mid wales
carthago chic i51.
Yes that is the one only we bought frombest eco shop
which is part of home shopping same price I bought it over phone .thanks jan & mike.
Techno
Jul 28, 2010
15,475
20,756
May 2010
100 watt panel will not exceed even 10 amps so yes but it may not be a duo controller?
Beacons
Jan 27, 2014
2,073
4,355
mid wales
carthago chic i51.
Mike says there is a 20 amp
controller with dual use same model but can you recommend one he said all ok
until he conected engine battery thanks.
Beacons
Jan 27, 2014
2,073
4,355
mid wales
carthago chic i51.
Ok thank you for your kind help.
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
A silly question ,you did connect both batteries to duo regulator first ,before connecting solar panel ? As recommended .
I have exactly the same system 20amp duo + remote with a 200w solar battery 1(1x110amp) @20% battery 2 @ 80% ( 2 x 110 ) and no problems as yet
Beacons
Jan 27, 2014
2,073
4,355
mid wales
carthago chic i51.
Hi thank you .no he connected solar then leisure battery all fine then engine battery
then sizzled and smoke from controller and leads from battery is that why .?
instructions did not state this.
Will this of damaged panel ?we disconnected
immediately .thanks mike.
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
OK best not to mention connection sequence to seller !
On all the regulators I've fitted it clearly states damage could occur to the unit and to connect batteries first then the panel.
So that's the way I have always done them.all with success .
And I always put a fuse bank in line to both the battery(s) and the panel.
Others fit them differently .
Can't say if the problem you have was caused by that but hope you can sort it ok (y)
Beacons
Jan 27, 2014
2,073
4,355
mid wales
carthago chic i51.
Thank you for kind advice I will have to get a new controller there are fuses inside thecontroller are they essential ?
Thanks.
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Fuses inside ? They didn't work then I recon from what you describe ,would have just blown and no juice would it not?
I have fitted a 6 fuse unit in line ,pull all fuses connect all wiring put in batt fuse's first then solar panel .
Beacons
Jan 27, 2014
2,073
4,355
mid wales
carthago chic i51.
Thank you will get inline fuses hopefully
will get sorted out thank you for your kind advice.
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
Hi,
The manufacturers instructions are not the best and are therefore not very clear. What pages two and three of the manual is trying to say is to connect the terminals in order 1 through to 6. IE terminal 1 first, followed by terminal 2 etc. The reason the battery(s) must be connected first is to enable the elctronics to automatically select 12 or 24V mode.
Manual is here http://www.epsolarpv.com/en/uploads/news/201310/1382338230686012.pdf
The specification of the unit is here http://www.epsolarpv.com/en/uploads/news/201408/1407810914399200.pdf
Claims "the failure rate is less than 2 per 1000 pcs" and also claims " Electronic protection: over charging, short circuit, battery reverse polarity protection".
Nothing about panel reverse connection!
Beacons
Jan 27, 2014
2,073
4,355
mid wales
carthago chic i51.
Many thanks for information
the instructions were very inadequate
we discussed this and looked for more
we will sort it out im sure .
many thanks jan&mike.
