HELP solar panel controller burnt out.
Discussion in 'Solar Power' started by Beacons, Aug 29, 2015.
  1. Beacons
    Beacons Funster
    Jan 27, 2014
    859
    718
    mid wales
    Hi today we fitted a solar panel all ok until connected to the controller
    Leisure battery then engine battery
    control panel sizzled then smoke
    all wiring correct and terminals etc
    checked why would this happen
    baird 100 w kit . Please can someone
    advise .thank you.
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    If you are 100% certain that you had made the connections in the correct order with the correct polarity then you should contact the seller
  3. Techno
    Jul 28, 2010
    14,107
    14,921
    Have you any information to share about the controller ?
  4. Beacons
    Beacons Funster
    Jan 27, 2014
    859
    718
    mid wales
    Hi mike took controller apart
    its a duo battery sent baird 100w kit no make visabl
    common yellow fronted with a red stripe poor quality we
    think circuit board melted.
    thanks
  5. Techno
    Jul 28, 2010
    14,107
    14,921
    Presumably you bought from trueshopping? I found they are not unreasonable to deal with. I would expect them to offer you a suitable discount equal to the rubbish regulator. It will be interesting to see what they value it at
  6. Techno
    Jul 28, 2010
    14,107
    14,921
  7. Beacons
    Beacons Funster
    Jan 27, 2014
    859
    718
    mid wales
    There is a 20 amp controller available would this be suitable please we will contact them monday .
  8. Beacons
    Beacons Funster
    Jan 27, 2014
    859
    718
    mid wales
    Yes that is the one only we bought frombest eco shop
    which is part of home shopping same price I bought it over phone .thanks jan & mike.
  9. Techno
    Jul 28, 2010
    14,107
    14,921
    100 watt panel will not exceed even 10 amps so yes but it may not be a duo controller?
  10. Beacons
    Beacons Funster
    Jan 27, 2014
    859
    718
    mid wales
    Mike says there is a 20 amp
    controller with dual use same model but can you recommend one he said all ok
    until he conected engine battery thanks.
  11. Techno
    Jul 28, 2010
    14,107
    14,921
    No I can't recommend a duo charger from personal experience.
  12. Beacons
    Beacons Funster
    Jan 27, 2014
    859
    718
    mid wales
    Ok thank you for your kind help.
  13. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    A silly question ,you did connect both batteries to duo regulator first ,before connecting solar panel ? As recommended .
    I have exactly the same system 20amp duo + remote with a 200w solar battery 1(1x110amp) @20% battery 2 @ 80% ( 2 x 110 ) and no problems as yet
  14. Beacons
    Beacons Funster
    Jan 27, 2014
    859
    718
    mid wales
    Hi thank you .no he connected solar then leisure battery all fine then engine battery
    then sizzled and smoke from controller and leads from battery is that why .?
    instructions did not state this.
    Will this of damaged panel ?we disconnected
    immediately .thanks mike.
  15. jollyrodger
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    OK best not to mention connection sequence to seller !
    On all the regulators I've fitted it clearly states damage could occur to the unit and to connect batteries first then the panel.
    So that's the way I have always done them.all with success .
    And I always put a fuse bank in line to both the battery(s) and the panel.
    Others fit them differently .
    Can't say if the problem you have was caused by that but hope you can sort it ok (y)
  16. Beacons
    Beacons Funster
    Jan 27, 2014
    859
    718
    mid wales
    Thank you for kind advice I will have to get a new controller there are fuses inside thecontroller are they essential ?
    Thanks.
  17. jollyrodger
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    Fuses inside ? They didn't work then I recon from what you describe ,would have just blown and no juice would it not?
    I have fitted a 6 fuse unit in line ,pull all fuses connect all wiring put in batt fuse's first then solar panel .
  18. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    only if you connect the solar first, hee hee
  19. Beacons
    Beacons Funster
    Jan 27, 2014
    859
    718
    mid wales
    Thank you will get inline fuses hopefully
    will get sorted out thank you for your kind advice.
  20. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    576
    378
    Cotswolds
    Hi,
    The manufacturers instructions are not the best and are therefore not very clear. What pages two and three of the manual is trying to say is to connect the terminals in order 1 through to 6. IE terminal 1 first, followed by terminal 2 etc. The reason the battery(s) must be connected first is to enable the elctronics to automatically select 12 or 24V mode.
    Manual is here http://www.epsolarpv.com/en/uploads/news/201310/1382338230686012.pdf
    The specification of the unit is here http://www.epsolarpv.com/en/uploads/news/201408/1407810914399200.pdf
    Claims "the failure rate is less than 2 per 1000 pcs" and also claims " Electronic protection: over charging, short circuit, battery reverse polarity protection".
    Nothing about panel reverse connection!
    • Like Like x 1
