Help - Reverse Polarity (1 Viewer)
KeefieWeefie
136
80
Bessacarr 520
Since 2012
Reverse polarity, always a good topic of debate:rolleyes:.
It's so easily checked with a tester and if necessary rectified with a reverse wired adapter.
I've always been cautious around electricity and for the pennies it costs to have it correct it's just not worth the risk!
I think you are correct! Those that think it's not a problem should not advise others. Like you I have made up an adaptor but they are also available from Amazon UK.
43,289
49,223
Reverse polarity....
The ability to freeze food in your oven, cook food in your fridge, turn on your lights to make it dark, make your charger drain your battery.
Reverse polarity won't really make these things happen, or anything else.
Making sure there's an earth is far more critical.
43,289
49,223
Can you give a documented reason why reverse polarity is dangerous in everyday use.... After all most of Europe don't have a specific polarity hense our love affair with correction adaptors.
Aug 6, 2013
11,949
16,551
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Same as us. I've got a tester and a RP adapter somewhere in one of the lockers. Neither have ever been out of said locker.
No, there is no real problem. Lots of people think they understand the issue when in fact very few of them have the first clue (y)
Me too. Reverse polarity will damage nothing and is not dangerous unless you're in the habit of working on appliances whilst they're switched on (or sticking knives in your toaster). I'd argue that there's more danger from another adaptor in the EHU than there is from RP. If your van has a built-in device to warn you of RP or prevent you from making the connection you may need an adaptor, In 35 years of tugging and mhing I have not needed or used an adaptor.
Aug 6, 2013
11,949
16,551
Kendal, Cumbria
since 1999
Those that use a term totally inapplicable to AC mains and that is more another marketing ploy than anything to do with safety should not offer an opinion.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
The only way reverse polarity on a UK van ( or UK electrics) would affect you is if live and neutral were reversed and your single pole switch, MCB or fuse blew or disconnected. Normally in the UK this would interrupt the live supply but if it was reversed it would interrupt the neutral wire and leave the live wire still connected through the switch and associated wiring.
not a problem with French wiring as all circuit breakers and switches are double pole but could be with UK wiring
bigtwin
5,224
9,906
Derby
Concorde
Since 2006
Dear, oh dear, oh dear.
In the immortal words of our dear friend 596 (now long gone), a little knowledge is a dangerous thing.
Those that advise it’s not a problem KNOW (not think!) that it’s not a problem. As pappajohn has requested, please advise the basis of your refuting conventional wisdom.
Ian
tuscancouple
552
964
Kent
None
You do realise that whilst it's always a relevant topic, this post is from four years ago, 2016? :giggle:
Mick
bigtwin
5,224
9,906
Derby
Concorde
Since 2006
Mick
He‘s a newbie and probably doesn’t realise.
Ian
May 7, 2016
7,228
11,691
West Sussex
Carthago Compactline
Since 2003
All RCDs are double pole, it's the MCB that are single pole in the UK (y)
I am not sure this is correct and if not it could be dangerous to rely on it. There are various references on the internet to single pole RCDs (Wiki, Screwfix). I know the RCD sensing is between both poles but it seems some only switch/interrupt one of them.
43,289
49,223
In the UK there should be no revered polarity if the campsite electric is up to specification so even single pole RCD is acceptable.
If it is reversed and a problem occurs they/their public liability insurers are liable as their electric testing isn't up to standard.....
Foriegn sites all use double pole as they dont have a specific polarity as a standard specification.
May 7, 2016
7,228
11,691
West Sussex
Since 2003
Thanks pappajohn . I was just concerned that one post said “All RCDs are double pole” when it appears that some may not be and therefore might not be suitable for continental use.
KeefieWeefie
136
80
Bessacarr 520
Since 2012
Our 2014 Auto Sleeper is fitted with the Sargent EC 500 PSU and it has a reverse polarity light fitted, Also our microwave isolation switch lights up if on reverse polarity. I have made a short lead with the positive and negative reversed and I've labled it reverse wired.
Here are the parts needed.
http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=281293138150
John.
Just found out that you can buy an adaptor to reverse the reverse polarity on Amazon for £15
bigtwin
5,224
9,906
Derby
Concorde
Since 2006
You’re a very naughty man; stop stirring it!
If you’re not being naughty, for the reasons outlined above, save your money.
Where there is an opportunity to pray on the fears of the ill informed, sales folks are not slow to capitalise on that weakness.
Ian
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Don’t forget to order your breathalysers for France while you’re there.
It's the law you know. :Eeek: :rofl::rofl:
Richard.
thebriars
1,149
2,182
Teesside
Since 1990
While UK domestic electrics use single pole MCBs, modern British caravans and motorhomes all use double pole MCBs. Also MCBs protect against too much current, it is the RCD which is the main precaution against getting electric shocks. RCDs work equally well with reverse polarity.
