Help Required With Tap Fitting.
Discussion in 'Motorhome Chat' started by lorger, Jun 25, 2015.
  1. lorger
    lorger Funster
    Jul 11, 2008
    6,401
    7,850
    Dumfries
    Just spent a lovely few days up at Fort William and climbing Ben Nevis with my daughter Sophie, yesterday when we got back to the van and sitting having a cuppa I heard the pump come on for about a second for no reason. I immediately turned it off and had a quick look around and found my kitchen drawer had a couple of drips of water in it so after further investigation I found the tap tail leaking so when I go home this afternoon went round the 3 shops in Dumfries and 2 told me I need a new tap other didn't have anything to fit. I doubt I need a new tap, so can any of you tell me where I can get similar to first pic below and if the second pic would do the job. First pic shows both broken one and what it should look like.
  2. sally47
    sally47 Funster
    Apr 29, 2014
    181
    68
    I'm pretty certain you can get those fittings at most B n Q or homebase
  3. lorger
    lorger Funster
    Jul 11, 2008
    6,401
    7,850
    Dumfries
    Thanks Sally it's not the blue part I need it's the white end and tail that fits into the blue push fit fitting
  4. Chris
    Chris Funster Life Member
    May 5, 2010
    16,758
    37,035
    kent
    My advice?
    Buy a new van(y)
    • Like it Like it x 1
  5. sally47
    sally47 Funster
    Apr 29, 2014
    181
    68
    Ok try caravan spares from Kineton near Banbury you can order on phone next day delivery if you can't find them I have there num somewhere let me know
  6. andy63
    andy63 Funster
    Jan 19, 2014
    2,325
    8,996
    south shields
    Had a similar experience where the plastic tail into the tap broke and tried to source replacements. ..
    Ended up getting a new tap and made sure I bought some spare tails that fitted it...just in case it happened again...
    I've kept the original tap just in case one day I come across tails that fit.....I did go back to the original supplier who tried to help but all the leads drew a blank...
    Hope you get sorted...
    Ta Andy.
  7. lorger
    lorger Funster
    Jul 11, 2008
    6,401
    7,850
    Dumfries
    Thanks for the replies, I'm not to bothered about the tails if I could get the wee white bit I could make up something with some flexi pipe.
  8. lorger
    lorger Funster
    Jul 11, 2008
    6,401
    7,850
    Dumfries
    Funny enough that's what the dealer suggested:)
  9. andy63
    andy63 Funster
    Jan 19, 2014
    2,325
    8,996
    south shields
    It's the little bits that fit the tap that I ment. ie these.
    Photo below in separate post ...sorry
  10. lorger
    lorger Funster
    Jul 11, 2008
    6,401
    7,850
    Dumfries
    Hi Sally tried googling them and can't seem to find them so if you don't mind I could do with their number.
  11. lorger
    lorger Funster
    Jul 11, 2008
    6,401
    7,850
    Dumfries
    I've looked at the taps bit they don't come with the tails so surely they must sell sepreately
  12. andy63
    andy63 Funster
    Jan 19, 2014
    2,325
    8,996
    south shields
    The bottom one for the new tap I had to get because I couldn't source the top one... It was 8mm with a different sealing arrangement. ..
  13. lorger
    lorger Funster
    Jul 11, 2008
    6,401
    7,850
    Dumfries
    The bottom one looks like it Andy of i could get one of them and a bit of flexi pipe I could make something up I'm sure.
  14. andy63
    andy63 Funster
    Jan 19, 2014
    2,325
    8,996
    south shields
    Ok... I've got 4... pm me your add. I'll send you two and hope it sorts you out... The bottom one is a 10mm tube with the o ring.
    • Like it Like it x 2
  15. WillH
    WillH Funster
    Feb 9, 2008
    1,785
    1,497
    SW Scotland
    I've used araldite in the past on a leaky shower tail.
  16. lorger
    lorger Funster
    Jul 11, 2008
    6,401
    7,850
    Dumfries
    Cheers Andy, I might take you up on your offer firstly I'm going to go back to the dealer and see if I can get some bits and bobs to make something up if not I'll be in touch.
  17. lorger
    lorger Funster
    Jul 11, 2008
    6,401
    7,850
    Dumfries
    I managed to get a hold of the tail in the last pic (red one) and it seems to have done the job time will tell.
    Thanks again for your help and suggestions even Chris :)
  18. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,906
    10,283
    I had the same problem a few years back with a swift van. Tried all the usual suppliers but couldn't source the connector. Even swift couldn't help or wouldn't whichever. So I changed the tap
    Problem is certain manufacturers source parts based on unit cost rather than quality and reliability
