Help required re:Floor repair. (1 Viewer)
Gorsecover59
45
17
Jersey
Swift,Lifestyle 530l
new
Hi Guys,
Hoping you can guide me in the right direction.
Have a 2002 530l swift sundance which when I bought it 4 1/2 years ago had some slight damage to the underside floor behind one of the rear wheels. It looked to be stone damage which is deteriorating slightly over a period of time. The floor is not soft, but in a few small areas the outer layer of ply is staring to come away and a few small holes are appearing.
I was thinking about using wood hardener followed by filler then a waterproof coat of some sort.
Some pics are attached
What do you think?
Any advice would be very welcome.
Martin
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Your method is sound for sure, substitute filler for a resin based material and your 100% there(y)
they do a product called bridging filler in the trade that is resin and
fibre glass strands mixed, just add the Catalyst and it sets in minuets
then choose either underseal or the old waxoil treatment as a finish, i would prefer waxoil as it too will soak into the wood
Car body filler is not waterproof and will absorb moister and expand when wet or damp
G
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
It certainly doesn't look too serious in the pictures, I would probably be tempted to seal it well as it is bitumen based or waxoyl as suggested by geo, then I would fit 2 pieces, maybe 200mm2 (one behind each rear wheel for symmetrical finish) of 6mm exterior ply sufficient size to cover the damaged area and coat these too with the bitumin or waxoyl, these will then act as sacrificial boards to stop damage to your main underfloor from stone chips etc and can be replaced as and when but would probably last years if sealed well.
Gorsecover59
Gorsecover59
45
17
Jersey
new
Gorse Hill,Geo and Wickload many thanks for your advice. Will get onto it.
Martin
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
G
Are you sure it's not waterproof, I have used as a repair in impregnated concrete on my drive still there 3yrs later never moved its flexible enough to use on cars
Not 100% about wood if that asorbs moisture then the wood would shrink/contract, seal the wood with SBR primer should be ok
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Yes 101 %
I have no idea what you have used on your drive but can assure you it is not body filler, the main ingredient of which is talcum powder
May I suggest you are not using the correct terminology
If its sticking to concrete and staying there I would gamble on it being a resin /catalyst mix
Gorse Hill
2,364
1,944
Stretford
Yes 101 %
Probably right about excact specc of what I consider to be body filler, however I got it of a good friend of mine who has a body shop, whatever it is certainly good s**t(y)
May 31, 2015
11,680
44,523
Cornwall
Ducato PVC
Getting Better
As a cabinet maker I would use a flexible waterproof filler for wood and seal with a sealant that will soak into the wood, wax oil would be perfect.... Then you'll find yourself doing the rest so it all matches in..:D(y)
