help required please ? (1 Viewer)
PAT N PAUL
129
60
retford nottinghamshire
fiat ducato MWB selfbuild
1 year
hello again i hope someone can help, vans a 09 MWB fiat ducato selfbuild, got back from scotland 10 days ago, it was faultless, not used it untill tonight turned it on and relised revs were up more than normal got to the top of the street and battery light came on.
Drove straight back home , turned van off and back on again battery light stayed off but revs were still high, any idea's please ?
regards landyman
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
Not 100% sure on this but could it be an alternator problem? I believe the throttle works via a rheostat or whatever it's name. Basically it's not a cable operated accelerator it works via 12vdc and resistance as the peddle is operated. If your alternator has failed on the bridge rectifier, it could be outputting AC volts or higher volts than the usual 14.2 vex. This could effect the revs and would also explain the battery light. Start the engine and use a test meter across the battery +Ve and -Ve first set meter to 20vdc range, it should read around 14.2 or 14.4 vdc. Then try 20vac range, that will give an indication what the charging voltage output from the alternator is and confirm if the rectifier has gone caput. The initial output of an alternator is AC volts, the bridge rectifier converts it to DC volts needed to charge your battery and supply your vehicle 12v electrics.
The bridge rectifier can be replaced without the need to fork out for a new expensive alternator. I hope this sorts you out ok,
Ps also check your alternator belt hasn't snapped, just another thought:)
Lance.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Most likely an alternator fault. The engine speed is controlled by the ECU as is the alternator charging. If the alt is giving a lower output than required the ECU raises the rpm to try and get it charging, if the charging remains low then the battery light comes on. Don't just change the alt though, get it checked threough the diagnostics as it could be summat else.
D.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
I have to say, well done to the members for providing an answer to the op's post. I makes me wonder.......is there any question that cannot be answered on this forum.(y)
Try this one, what is Managements inside leg measurement ? Anyone wanting to come and measure it, is likely to get a slap. :ROFLMAO:
Apr 29, 2009
1,203
740
West Sussex
Burstner Nexxo T740
since 2008
We had the same issue on our 2007 - same symptoms - the Alternator was replaced and has been fine since.
DBK
18,019
48,071
Plympton, Devon
PVC, Murvi Morocco
And within exactly six hours at an unsociable time of day!
Nov 3, 2013
3,170
9,373
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Nay! SMALL Tweeting
