HELP required near Guadamar
Discussion in 'Motorhome Chat' started by wiljoy, Apr 16, 2015.
  1. wiljoy
    wiljoy Funster
    May 23, 2008
    857
    940
    Crook, Durham
    Can any funster please help. My fridge has decided to malfunction on gas operation. It's fine on electric. My motor home buff in the UK is convinced it is the thermo coupling. This van fridge hasn't been used on gas so it appears to have seized. Can anyone suggest a reliable repairer near Guadamar.
    Many thanks in anticipation.
  2. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,761
    39,072
    Just in case you have not already, take the cover off and make sure a bit of rust has not dropped down and covered the jet...
    I doubt if it has not been used the Thermal Coupler would be duff..
    Even if it has not beeen used on gas, some rust will acrue in the chimney and as said a bit may have dropped down... only takes a small particle..
    • Like Like x 1
  3. old-mo
    Oct 16, 2008
    12,761
    39,072
    PS........... There is or was a guy who dabbled in second hand Mo,Ho`s on the road going East just past La-Marina campsite that may help.. (y)
  4. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,508
    12,657
    Bolsover, Derbyshire
    some fridges are very sensitive to level siting and may not work if not level (enough)
  5. wiljoy
    wiljoy Funster
    May 23, 2008
    857
    940
    Crook, Durham
    Thanks. Have had chimney and igniter cleaned. It fires on gas but only runs for 4 minutes. According to the Dometic guy in the UK this is a thermo coupler fault. I need a new Unit fitted while here.
  6. old-mo
    Oct 16, 2008
    12,761
    39,072
    Unusual for little use...... but sounds about right..
  7. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,697
    11,823
    Plympton, Devon
    Can your Dometic guy not recommend someone? They must have a European network.
    • Like Like x 1
  8. jumar
    jumar Funster
    Nov 6, 2012
    856
    1,164
    Spain
  9. MickyP
    MickyP Funster
    May 13, 2012
    101
    41
    Alhama de Murcia, Spain
    Caravanas Sangar 968554586
    37.39.34N 00.54.14W
    Near Cartegena
    Very good service.
