Help removing Mobilevetta floor (1 Viewer)
greekone47
Milton Keynes
Hi Top
I'm a newbie
Hi can any one help me. I have bought a 6 Birth Mobilvetta Driver 57 Motorhome2000 on impulse and have found that all of the wooden floor has to be replaced. I bought the Motorhome as seen from a private sale. I would be grateful for any info or drawing showing how to remove all the units out and electrics so that a new floor can be fitted. Please help thanks
TheBig1
17,591
42,996
wow, that will be a mammoth task to take on DIY. basically the vans are built from the floor up. first they fit the floor and bottom cupboards, then add walls and roof. the walls are supported by the floor
the only way is to unscrew interior fittings then replace the floor in sections whilst the remaining floor and temporary supports hold up the sides. you need to use high quality waterproof ply and foam insulation. its a massively expensive and time consuming job. often costing more than the van is worth if paying for it to be done
i just hope you didnt spend too much buying the van and can sell it on for parts possibly
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Floor implies some plywood but what is the frame like. If that's gone you really are stuffed.
But nothing is impossible and some wood isn't mega expensive. So find an easy section open it up and see if you can cope. The really critical area is the joint between the sides and the floor, if these have gone the body is held on by a scrappy bit of aluminium skin and the units inside. A good place to start would be an easy to get at section that reaches a wall.
Naturally the number one priority is find the leak.
Someone on here replaced the wooden frame with aluminium, said it wasn't much more expensive, you might find it if you search for aluminium + rot.
