HELP! Problem with gaslow fill in France (1 Viewer)
Aug 21, 2015
1,006
841
Norfolk
Autocruise starblazer
since 2015
Having no success filling the gas cylinders. Have the French adaptor ( same as garage here) nozzle fits the adaptor but system just will not fill. The bottles are open by the way.
We are having such a nightmare here, which I'll tell you all about later - you will not believe it!!!!
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Bottles should be closed but that would not be the cause
Reactions: JJ
Jan 22, 2013
1,252
59,973
London SE
A class Adria vision I707
since 1971
you are meant to have the valves on the bottle shut before trying to fill,
Reactions: JJ
Techno
Jul 28, 2010
15,475
20,756
May 2010
Andy, my Gasits will not fill if I have the taps open I found this the hard way.
Are they the old gasit or the gasit plus? certainly the old ones just like the old gaslow will fill regardless has many people have done inadvertently either by not reading the instructions or just forgetting
Madeinengland
Aug 21, 2015
1,006
841
Norfolk
since 2015
These are the bottles we have.
Madeinengland
Aug 21, 2015
1,006
841
Norfolk
since 2015
We definately had the valves open. Do you think this is our problem?
R
Robert Clark
In France we found the following applied when filling our Gaslow:
1 - turn off bottles
2 - connect nozzle to filler
3 - squeeze trigger and lock open using catch on trigger
4 - press and hold button on pump (usually black or green) until filling is complete
Sometimes there is a delay before filling starts, sometimes a long delay as I think the cashier needs to turn on the pump.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Mine are the plus 4 hole version
Techno
Jul 28, 2010
15,475
20,756
May 2010
They are the old bottles and they should be closed but certainly will not be the cause of not filling.
It is more likely they will not turn the gas on because of your internal filler
Madeinengland
Aug 21, 2015
1,006
841
Norfolk
since 2015
:) Wow thanks.
We're in need of a coffee then we try again with valves closed
If this doesn't work were near Le Havre and we coming home. For a holiday....
Dec 12, 2010
5,408
21,550
Cumbria
since 2011
Couldn't get ours to fill once, my fault totally. After years of switching on all sorts of electrically powered machinery, small button ON, big button OFF, I hadn't noticed the small button was red and the big button was green :whistle:
Madeinengland
Aug 21, 2015
1,006
841
Norfolk
since 2015
Just an update on the gas saga.
We tried again with the valves shut - no success. Went to another garage where the garage man helped us. Now he managed to get a minute amount in and seemed to think they already had gas in. So we still don't really know what's what.
Yesterday at one garage stop there was another British guy who'd just picked up what can only be described as a coach. It was a huge black, beautiful, brand new MH that he'd just driven off the forecourt and was on his way down to Spain. It was about the fourth place he'd tried to fill without any joy, and he had the same fitting as us - the French one.
Must go now as phone running low and the second 12v thing has just gone pop.
Will start a new thread when we can chill somewhere with electric and tell you about the 'biggie' mishap. You'll love this one - I'm just about ready to laugh about it. :mad: Thanks for your help today :)
Dec 23, 2014
2,176
2,806
South Somerset
Carthago C-Line I 50
Since 2009
I have the R67 Gaslow cylinders and it makes no difference whether the valves are open or shut the cylinders can still be filled; however, for safety sake I do shut them.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
I have had trouble a couple of times, once was a faulty pump that gave a couple of litres and shut off. Another was when I foolishly pressed the wrong button (the emergency stop one). Otherwise no problem with or without the French adaptor.
I've never found a pump using the alleged euro standard fitting (the most expensive adaptor) but I suppose there must be some.
Badknee
7,407
412,437
notloB
Vantage Neo
Living the dream.
If an experienced garage geezer couldn't fill it are you sure they aren't full and the regulator isn't foobard?
Jul 30, 2015
231
118
Barnsley, South Yorks
Auto-Trail, Tracker FB
45 yrs Tugging
If in doubt wether full or empty its simples to find out unfasten the securing straps and lift up the bottles you should know by feeling the weight of them if full or empty.
We had a problem at Chester van 10 month old regulator given up now replaced by me via dealer who payed no more problems but did fit a gas filter at same time to stop it happening again.
Cliff
Dec 23, 2014
2,176
2,806
South Somerset
Since 2009
The auto changeover valve in the picture seems to be showing one cylinder is low if not empty. Of course you could always find a gas fitter in France to check it over. @yodeli
Lenny HB
53,398
149,817
On the coast in West Sussex
Hymer B678 DL
Looking at your pic the regulator is below the changeover valve, this is very bad practice. The regulator should be as high as possible in the locker above the cylinder outlets to help prevent the regulator gumming up. Could it be your cylinders are full but the regulator has packed up?
Madeinengland
Aug 21, 2015
1,006
841
Norfolk
since 2015
Thanks all. Thought it was empty cos the pressure was really low. We're going to assume they're full @chaser and when we stop somewhere have a closer look at things. As said unstrap and feel the weight.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
No. I often forget to turn off.
What did catch me out once was a Big Red emergency stop push on a pump, someone had hit it so the pump was dead, no motor running. A quarter turn, it popped out and I filled.
Dec 23, 2014
2,176
2,806
South Somerset
Since 2009
If by the pressure being low you mean that the flames on your gas hob are low then it may be a regulator fault; that is how my last one died. In any event if it is they are readily available in France and not that difficult to swap. Just make sure you get the right fitting, either 8mm or 10mm.
Jul 30, 2015
231
118
45 yrs Tugging
the new Regulators now come as a
10mm But also supplied with a
adapter that converts it to 8mm
it saves the manufacturer making 2
sizes.
cliff
