Help please (1 Viewer)
grandpabeard
36
Solihull West Midland
demountable
since May 2009
Hi all we have a demountable motor home and we have had a slight prang in it.:cry: the side has a dent/scrape about 3-4" long and about 1" high it has cut into the aluminum I have straightened it out and put some waterproof tape over it and then put plastic over that what would the best thing to repair it until I can get the panel replaced
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Sounds about right for a good temp repair.
Peter
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
Get into Halfords, buy a pack of fibreglass filled filler and some oxide paper. Rough up the sunken parts and fill with the filler. It will be stronger than the ali. Not much more effort to do a permanent job if you can get matching paint.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Filler and fibreglass are porous. Seal with a waterproof plastic resin bond first to seal up the crack/split, and then fill over as required. Make sure you use some good quality filler. Rub down initially with 80 grit, and work your way down to 1500-2000. You will need to reskim a few times - no one gets it right fist time! Once tat is done and flat, wet and dry and prime, 3 or 4 layers wet and dry and top coat 3 or 4 layers, flat and buff.
You could always get a quote from a bodyshop - you would be surprised how cheap they can be. I would expect no more than ÂŁ400 to repair and repaint the side of a demountable at top whack rates.
May 22, 2008
484
Seems a bit drastic to replace the panel for minor damage like that with all the possible leaks due to possible bad sealing of joints, I would just fill the damage with waterproof resin, paint the area of damage and then cover the repaired area with a sticker, transfer or reflector of some sort.:thumb::thumb::thumb:
