help please.... (1 Viewer)
Ricky Hunt
5
United Kingdom
eldiss autostratus 200 EB
since 2015
I'm viewing angle Eldiss autostratus 2000 Eb.It's a 2000 model. Looks very tidy.
On the picture of the bathroom I've noticed 3 little drill type holes in the shower tray for.
The seller says it's for drainage.
Can someone just confirm why it may have little drill holes in the shower tray floor?? Thank you.
Feb 22, 2011
9,785
20,150
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Ask whats wrong with the plug hole drain into the grey waste tank and why he did it.
Additional drilled holes aren`t really going to work.
Puts a whole new slant on grey waste disposal.....
13,079
101,442
Bolsover, Derbyshire
Hymer S800
not long enough
Does sound very odd and potentially quite worrying, if the holes do not drain straight to ground I dread to think where any water goes, worth looking underneath, if you cant see the bottom of the tray I would leave well alone
Buyer beware me thinks (y)
Theres plenty more out there, if you can see the tray from underneath, at least factor in the price a new tray, including fitting, if you do decide to go ahead, it will not be cheap to change and it will be hard to sell on when you do unless changed
R
Ricky Hunt
5
United Kingdom
since 2015
Thanks. See the motorhome looks lovely etc..... I just saw these tiny holes and it made me think.
I asked the seller and he said they were drainage holes.......
Carol
14,050
112,111
North Wales.
Have you done a damp check, could show if water is going somewhere it should not be.
R
Ricky Hunt
5
United Kingdom
since 2015
I'm viewing this tomorrow morning carol. All I've got is pictures and the description etc.....
As I say it looks a very well cared for home but why would there be three times tiny holes
Carol
14,050
112,111
North Wales.
When you check some of the things you need to definitely check Damp with a damp meter, the pay load. If you can have a look at Jims check list for buying a van. :)
9,785
20,150
Hymer B544 A Class
Since 2015
Are you sure they are holes ? could they just be marks in the plastic.
If the seller is genuine he will tell you why they are there / what caused them.
As said, factor in a replacement tray, might be worth ringing a dealer to get a ball park figure before you view it
Let us know how you get on
Carol
14,050
112,111
North Wales.
You only have 5 free posts before you need to become a full member £15 a year, the information, rally's and banter on here it's well worth it. Good Luck with your viewing.
19,731
52,009
uttoxeter
ambulance conversion
50 years
Why three tiny holes, why not a larger one, and has been said what's wrong with the drain hole, sounds like a wrong un to me.
GeebeeJaybee
293
349
St Helens
A Class - Adria Vision
newbie
I think I have found the listing.....
Broken Link Removed
Those holes are not a good idea in my opinion as they will not lead to the waste pipes and hence water is just leaking down.
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I suspect the seller doesn't know either. It's hard to imagine anyone would drill holes to let water onto the floor. Try probing to see where they go & if completely through the tray is the floor soft or is there something else under there. I wonder if they were drilled for foam injection to firm up the shower tray. If there's nothing untoward underneath they can easily be filled. A worthwhile negotiating point though :)
appydaze
728
1,845
southend on sea essex
Merc high top
20 years
The only way you would drill the shower tray would be a fault in the drainage from said tray. Sounds like a right bodger.... walk away
