Help please! My Dometic Fridge is keeping me awake! (1 Viewer)
MrsM
35
11
Lincolnshire
Low Profile Coachbuilt
Not so new at motorhoming now, but still learning!
Hi ever so helpful Funsters.
My husband and I are deep in the Auvergne region of France and after a long day driving through the rain, we set up camp a couple of hours ago in our 11 month old Burstner Ixeo.
However when we connected to the campsite electric the Dometic RMDT 8501, 8505, 8551, 8555 (daren't open the door again to check) a bleeping started lasting for 15 seconds then stopping. It started again after 2 minutes and the blue light on the outside was flashing too. Everything else appeared to be normal. The instruction books states this to be indicating a fault with the light inside and to check the door catch etc. However we checked this thoroughly and the light seems to be working perfectly.
We have switched the fridge off a couple of times, waited a few mins then popped it back on. Still got the bleeping!
We would really appreciate any help you can give as we are either going to get no sleep, or we will need to switch the fridge off and risk being stinked out by the mountain of French cheese we bought, including a rather smelly Reblochon!
Thanks in advance!
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Check the door seal hasn't come out at the bottom of the door.
Is it set to AES or have you selected 230 volts?
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
To eliminate the ehu on the site which maybe a reverse polarity, have you tried it back on 12v or gas ,and if so does it still bleep ?? :think:
Could be a warm beer alert :)
MrsM
MrsM
35
11
Lincolnshire
Thanks but the door seal appears ok. Tried it on Auto, mains and battery, but still bleeping! Had it in gas this afternoon at our lunch stop, but no bleeping then.
Confused.com!
Techno
Jul 28, 2010
15,475
20,756
May 2010
Beeping usually means the door is open or the power source has failed.
Battery only works with engine running. If it works ok on gas I would suggest the voltage is too low or a dead circuit.
MrsM
MrsM
35
11
Lincolnshire
Thanks. We have a polarity checker and all is fine on that front. As mentioned above have checked all other power sources.
Yes my husband agrees in the alert and has had a warm bottle of Spitfire followed by a local ish Merlot to go with the Reblochon before it stinks the van out!
R
Robert Clark
We had the same problem
It's caused by condensation on the interior light
Start by removing the interior LED light ( it's got a plug fitting)
Next check that the door lock mounting on the interior of the fridge is square to the door
Ours was slightly mis aligned, which kept the door slightly open
This caused condensation to form on the LED light
Hope this helps !
MrsM
MrsM
35
11
Lincolnshire
Hope this helps !
Thanks Robert. Reckon you might be right as the bleeping stopped a few mins ago after being on a while. We also saw some condensation on the outside of the freezer door after we parked up.
You are a star! Moral of the story is probably not to panic about the slowly warming French cheese and stop opening the door too much!
motorhome42
48
15
North Tyneside
Auto-Trail
Since 2009
I think this is the same problem we had last year. If you have an instruction booklet it gives the cause of this bleeping as being a faulty sensor. The fridge / freezer will still work but only at a constant temperature which can't be regulated. I don't think the cost of a replacement thermostat is huge (ours was done under warranty) but if it's relevant all Dometic appliances have a three year warranty. I seem to recall that there is a way to stop the bleeping but I can't remember how - sorry!! Have you tried contacting Dometic and asking for their advice??
R
Robert Clark
While you are on mains, switch the frame heater on.
I think the frame heater only helps if the freezer door has frozen itself shut, preventing the door from opening
Techno
Jul 28, 2010
15,475
20,756
May 2010
Page 18
All models are equipped with a frame heating (12VDC/3,5W) around the freezer compart- ment. During summer months with high tempe- ratures and humidity the metal frame may have water droplets forming. To evaporate these droplets switch on the frame heating with switch (3) . The LED (5) indicates that the hea- ting is on.
The frame heating is in operation with a preset- ting of 2 hours and switched off afterwards automatically. The frame heating can be deacti- vated every time by pressing the button (3) .
Engineer told me that on later versions it stays on until you turn it off but I'm not so sure
RMD 8501 RMD8505 RMD 8551 RMD8555
http://www.rvworldstore.co.nz/media/wysiwyg/Manuals/RMD8555_Operating_manual.pdf
R
Robert Clark
Page 18
On ours, (which is brand new) it has a choice of settings, from a couple of hours to 24/7
Though I'm surprised that it only works on EHU, what are you meant to do if you've no hook up?
Though from what you wrote its not necessarily saying it needs to be switched on 24/7, only when condensation appears?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes
When I have tried mine off hook up the amber light doesn't stay on. However I've suffered two years of trouble with it so far.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Engineer at Malvern show had to resort to fitting a 7000 series controller to mine to get the tw@t working on gas.
It seems the front control panel goes faulty after the first 36 hrs or more on gas, probably condensation
StefAndDi
408
931
Near St. Austell, Cornwall
Ceased motorhoming 1/3/16
2010 to 2016
Hope this helps !
Exactly the same as @Robert Clark.
Condensation builds up on the inside of the clear plastic cover which is clipped over the light unit.
It's happened to us twice. Now I haven't bothered to put the cover back on.
Stef.
Lenny HB
53,421
149,945
On the coast in West Sussex
Hymer B678 DL
Had the same problem on our 8505 fridge, it is probably the door open warning switch, took the swich housing apart re-bent the metal strip that operates the microswitch.
For a tempory fix you can just unplug the cable loom at the back of the switch housing, you will loose the fridge light as well as fed from the same loom.
MrsM
MrsM
35
11
Lincolnshire
Thanks everyone for all your help. We've added it to the growing list for when it next goes back to the dealers.
Well at least it gave us a good reason to scoff all the French cheese!
Aug 19, 2015
160
175
Derbyshire
Elldis Autoquest
I'm on my 4th control panel in two years .asked for new frige
No luck so far finger s crossed. Ken
