movan
Recommendations please for cleaning inside. Many of you will know that Helen is a mature Hymer and before I commence our odyssey around France at the end of April I would really like to give her a real birthday scrub inside. I did a sort of wipe over last year but now I have the time I would like to do a proper job.
I did a quick scan of the thread titles on this forum and none seemed to answer my question. So help please, I need to clean the roof lining, which is a hard non cloth type, the walls - usual board with an irregular surface and the floor (I removed the vintage shag pile last year leaving the "lino" exposed). I gave the floor a wipe over with washing up liquid and rinsed which brought is up quite well.
So suggestions please, I do not mind spending the money and have a supply of elbow grease, simply want to get her well turned out.
Thanks for any suggestions (suggestions about scrubbers to be relevant please)!
Clive
It is on a car body not motorhome. The photo is at post #79I can't see Indys post that describes exactly what has happened ? But am I right in saying the superglue is on paint that is on metal or is it on composite Motorhome bodywork ? Sorry I have looked through this thread but can't find enough to go on ..
Ive helped get into a few roller shutter locks over the years that had been superglue by some lovely little scrotes. ..Heating the glue slowly and carefully
Heat and acetone as I mentioned above usually worked but didn't think heat was an option on car paintwork...
It sounds like you say a bit of a skill and beyond most diy folk..
Andy
Hi everyone who has tried to help. I have sanded the area with a very fine paper and fairy liquid until very smooth then sprayed with correct paint colour , several coats later I've left it to harden, hope it's OK when I check it tomorrow !!
@Cleve Don't be a chauvinist.
Apologies, did not mean to be.
................... and breathe .............OOOOOOOOOOOOOOOOOOOhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh...
I discovered that the Mr Muscle floor wipes are great for the job. £1.49 in the discount store. A couple are more than adequate. Wouldn't be surprised if they did ceilings too. Be careful of doing the plastic windows, don't use the proprietory window cleaners as they can damage the surface. You can get a special cleaner for that job. Hope this helpsRecommendations please for cleaning inside. Many of you will know that Helen is a mature Hymer and before I commence our odyssey around France at the end of April I would really like to give her a real birthday scrub inside. I did a sort of wipe over last year but now I have the time I would like to do a proper job.
Clive
