Help please. - How can we reduce the noise / reverberation from Gas Heater
Discussion in 'Tech/Mech General' started by Dogeared, Jan 2, 2015.
  1. Dogeared
    Dogeared Funster
    Jan 16, 2013
    226
    193
    Blackburn
    The gas heater in our autoquest 155. is under the bed, and when it starts up at night the reverberation is keeping my better half awake. (a) is the reverberation normally quite loud?, and (b) would noise insulation reduce the reverberation, or is there a better way to nullify the sound.
    Any ideas on how to reduce the noise, (not from the boss, that doesn't work), or other guidance would be appreciated.
    Baz
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,720
    17,333
    YO11 2BD
    My suggestions...
    Mount the heater on softish rubber feet and don't screw down too tightly....Just enough to stop the feet moving
    Ensure all distribution pipework is secured and can't rattle around.
    Ensure nothing is resting on or against the heater body or pipework.
    If it continues it may be the blower fan is out of balance.
    Can be balanced but means a strip down to get to and remove the fan.
    If the reverberation is caused by combustion noise (roaring) there's little can be done.
    • Like Like x 1
  3. pappajohn
    Aug 26, 2007
    29,720
    17,333
    YO11 2BD
    Duplicate post
  4. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    If its your space heating you refer to, get a silk filled quilt, no heating required and it will only take up the space for two bath towels. As for soundproofing, you need to isolate the heater from the van. I would mount it on a piece of wood and sit the lot on soundproofing material, like rubber or some of the stuff you get in packaging.
    • Like Like x 1
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    switch it off and snuggle up closer
    • Like Like x 1
  6. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,585
    22,498
    Narrfoook
    We had a similar issue with a water pump.
    Ended up mounting it on an 1" thick pad of Styrofoam
    • Like Like x 1
  7. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,552
    3,361
    Telford, Shropshire
    I think your motorhome uses the Whale blown air heating system, previously known as Propex and yes they can be noisy. Not a lot that can be done really its just a noisy heater although according to Elddis website yours should have the 4KW unit with "quiet night time mode" whatever that is.
    D.
    • Like Like x 1
  8. pappajohn
    Aug 26, 2007
    29,720
    17,333
    YO11 2BD
    Come on Dave, a man of your experience......
    It means it only works between 8am and 10pm.
    • Like Like x 4
  9. dave newell lvs
    Oct 31, 2008
    2,552
    3,361
    Telford, Shropshire
    You might well be right PJ.
    D.
    • Like Like x 1
