Help please;;; grafiti
Discussion in 'Tech/Mech General' started by travla, Apr 9, 2010.
  1. travla
    travla Read Only Funster
    Apr 29, 2008
    6
    Hi all
    some @"*!! has spray painted from an arisol on my van any ideas to remove it would be great,
    they done halfe the street :Doh:
  2. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
    T cut or if its pretty thick a proper cutting compound and an electric mop will remove it. Just be careful if its on the morohome bit instead of the van bit as the paint on the motorhome bit will be very very thin :Sad:
    If all else fails and its really thick ring the insurance company :Eeek:
  3. IrasciBill
    IrasciBill Funster
    Mar 6, 2010
    186
    19
    SW Scotland
    Paintwork
    Hi,
    Sorry to hear about your problem. You can get special "Graffitti Removers" but I think they might be too aggresive for MH paintwork. Might be worth asking a local coachworks for advice. If they've done half the street the local coachworks should be quite good at removing it!
  4. dikyenfo
    dikyenfo Read Only Funster
    Aug 29, 2007
    44
    lincoln
    This is one reason that I keep a good layer of polish with a finishing coat as nothing will stick to it very well. To get anything to stick you have to use meths or other to remove it. If you have used one of these polishes then it should come off with T - cut.
  5. hailman
    hailman Read Only Funster
    Nov 4, 2009
    150
    12
    IoW
    Disclaimer! :BigGrin:
    Get some cheap thinners/gunwash from a local paint store (car type) and try a SMALL area with some clean rag or paper towel, wiping off straight away. If it softens the original paint at all, STOP!
    If you use a machine polisher chances are you will wear through the original paint around the graffiti quicker than removing it. Even if this does not happen and the graffiti comes off it may leave a `hologram` trace of the graffiti which could be seen when looking across the affected area.
    Get it done as soon as before it gets baked on by the sun. Aerosol type paints tend to be soft and not too hard to remove. You may try a drop of petrol as this tends to soften these types of paint.
  6. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    If you cann get to it quick enough ordinary car polish with lots of elbow grease will remove it
  7. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,007
    5,232
    Wirral
    Hanging is too good for them. Some people say that WD40 will remove paint like this.
  8. travla
    Apr 29, 2008
    6
    Grfiti
    Thank you for your help,
    many thanks all will let you know how I get on I am really gratefull for all the advice :thumb:
  9. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    they tell me in Saudi it is hard to re offend with no hands:thumb:
