Help please - epsolar Viewstar controller
Discussion in 'Solar Power' started by Daveg, Jun 2, 2016.
  1. Daveg
    Daveg Funster
    Sep 2, 2012
    124
    144
    Perthshire
    I changed our leisure battery last week. The solar panel regulator shows that the panel is working fine, but there is no charge going into the battery. Before I changed the battery it was performing, if not optimally.
    I have looked at the manual and it is beyond my very limited understanding. I can't find any reference to the problem in Troubleshooting and don't know how to figure out what to do. I am tempted to try the reset option, but don't know if that will fry something.
    I am intending to get the controller replaced later in the year, having been told by an expert that it is badly fitted and a poor fit with the shaudt eletrobloc. I would, however, like some use from the panel in the interim, as we spend a lot of time off grid.
    Can anyone advise please?
    Dave
  2. treetops1
    treetops1 Funster
    Feb 25, 2013
    920
    1,047
    yorkshire
    i have have an inline fuse between control unit and battery ,if you have ,check its not blown.
  3. denisejoe
    denisejoe Funster Life Member
    Aug 6, 2014
    1,188
    876
    Isle of Sheppy
    when you changed the battery did you disconnect the solar as well?
    try disconnecting solar and battery then reconnect battery then solar panel
    joe
    • Thanks Thanks x 1
  4. Daveg
    Daveg Funster
    Sep 2, 2012
    124
    144
    Perthshire
    I just swapped the new one in without touching the solar regulator, which is directly wired onto the terminals. No inline fuse either - one of the things whoever installed it got wrong apparently.
    Dave
    • Informative Informative x 1
  5. denisejoe
    Aug 6, 2014
    1,188
    876
    Isle of Sheppy
    Try disconnecting solar and battery then connect battery then reconnect solar
    Joe
