Help please damage to our motor home
Discussion in 'Motorhome Chat' started by The gasman, Nov 21, 2015.
  1. The gasman
    The gasman Funster
    Jun 29, 2015
    86
    60
    Southampton
    Hi I hope someone is able to help, as this is my fault. When loading items into the MH Cooker (MH).jpg I did the damage. I need to find some corner cladding to cover it up. Any advice welcome.
    Thank You in advance!
  2. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,613
    2,132
    Scotland
  3. hilldweller
    Dec 5, 2008
    27,231
    26,236
    Macclesfield
    Sticky backed plastic.
    • Like Like x 1
  4. Speve
    Speve Funster
    Jul 29, 2013
    2,095
    1,844
    Salisbury
    Look like you could take that out and replace,trying to repair it would probably not look to good as it's a very thin veneer on MDF.As Brian said sticky plastic but probably need to fill damage out flush so that it does not show through or a nice piece of stainless angle fitted on would look good also save you damaging it again.
    • Like Like x 2
  5. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    If it's the same edging both side's any replacement or cover over would look a lot better if both sides were the same. try B n Q they sell all sorts of stuff or you local double glazer suppliers they have all sorts of covers. Pete
  6. Gellyneck
    Jun 5, 2014
    1,613
    2,132
    Scotland
    Just another thought.
    If you can remove the damaged piece is it "reversible" with the damaged corner going to the inside?
  7. The gasman
    The gasman Funster
    Jun 29, 2015
    86
    60
    Southampton
    It looks like an edge but is part of the side panel so cannot be moved. I have found some corner strips but not the right size. I think the best idea may be sticky back plastic it can be made to fit
    • Like Like x 1
  8. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,135
    3,544
    walthamstow east london
    if its a place its likley to get damaged again you could cover it with a metal angle strip and do other side to match
  9. The gasman
    The gasman Funster
    Jun 29, 2015
    86
    60
    Southampton
    If I load it properly it won't get damaged again
  10. Daveo2006
    Daveo2006 Read Only Funster
    Jan 25, 2013
    1,168
    987
    kent
    Hang a tea towel over it.
    • Like Like x 2
  11. Glandwr
    Glandwr Funster
    Jul 10, 2014
    645
    1,822
    the Berwyn Mountains
    Fill it, rub down and paint in a colour to match/complement the panel on the left of it.
    Dick
  12. kelv
    kelv Funster Life Member
    Jun 23, 2014
    330
    273
    leicester
    You can get wood effect corner strips just put corner strips in ebay there are lots of colours simple job to glue on once cut to length.
    You can also try a local kitchen company who make there own cabinets and see if they have any veneere to match.
  13. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,000
    11,422
    East Sussex
    I'd suggest giving it a light sand, then prime and paint it black or dark brown to match the metal trim its next to
    • Like Like x 2
  14. namwaldog
    namwaldog Funster
    Jan 2, 2015
    469
    778
    Cumbria
    Presuming that it is MDF with a veneer of plastic type material on it, have a look in the manufacturer's brochure for your MH to see if there is any description of the kitchen or wood trim, ie 'Ash ' finish to the wood. (it looks like Ash to me) then look for Fablon or other sticky backed plastic with the relevant woodgrain and re-cover the whole piece.
    Amazon do a similar one at..
    Bear in mind that when you rub it down with sandpaper to get rid of the rough edges, you will probably create a flat spot on the radius that may cause a wrinkle in the material.
  15. The gasman
    The gasman Funster
    Jun 29, 2015
    86
    60
    Southampton
    Thanks everyone
  16. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,402
    2,666
    Surrey
    I am on 3G at the mo, and I can't get tags to work. Peter Marshall is quite correct. Both B & Q and Homebase have a section in the timber aisle, where you can buy mouldings. I have purchased this exact moulding, it comes in roughly 6' lengths, rip that one out an replace with the new :D
    • Like Like x 1
  17. TeeMyob
    TeeMyob Funster
    Jul 18, 2009
    496
    320
    Cheshire NW UK
  18. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,070
    1,468
    Dover
    It is more like chipboard with a cardboard printed surface, get a piece of alloy from B&Q and stick it over the corner and cover it all.
    • Like Like x 1
  19. scotjimland
    Jul 25, 2007
    28,934
    25,602
    I'd go with what he said ^^^^ angled ally
    no more repairs
  20. petensal
    petensal Funster
    Feb 22, 2012
    160
    148
    Lincoln
    You can get laminate flooring repair kit try eBay, may take a bit of time but do able.
    Or maybe try car body wrap vinyl in a contrasting colour.
