help on wiring 240v switch to 12v wire.
Discussion in 'Tech/Mech General' started by Welsh girl, Apr 10, 2015.
  1. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,794
    1,361
    living the dream.
    We have bought an inline switch, for a household supply but was informed that we could use it to put in after an inline fuse from the leisure battery so that we can just switch off the inverter wired to the battery instead of removing the fuse every night.
    Every time the fuse is inserted it sparks and I'm a little worried that the battery will blow up as it is only around 12 inches away from the battery that is housed under the bed.
    The battery is normally used for the orthopedic electric beds( already fitted in van) but is used to power other things via an inverter as the electric function is hardly used for the beds.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    You could put it in the inverter feed wire but it would last milliseconds.
    230vac switches are generally rated at 10amps or less.
    ...your inverter could be needing 10 times or more than that amount of amps.
    To do it properly you need a heavy duty relay capable of 200 to 300 amps and a switch to control the relay.
    If the inverter is that close to the battery DONT keep removing and inserting the fuse.....the battery may be gassing and could ignite with a very big bang.
    Turn off the inverter at its own switch.
    • Like it Like it x 1
  3. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,929
    6,828
    West Sussex
    Yep & only about 2 amps switching DC.
  4. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    How big is the inverter.?
  5. Welsh girl
    Nov 7, 2009
    2,794
    1,361
    living the dream.
    The inverter is 300 watts. Pure sine wave.
    The switch is rated at 6a, 250v.double pole.
  6. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,942
    1,961
    Warwickshire
  7. Welsh girl
    Nov 7, 2009
    2,794
    1,361
    living the dream.
    We need to remove the inverter to use on the front leisure batteries that are charged via the solar panel and the engine when driving.
  8. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,078
    3,477
    Eastbourne East Sussex
    Just use a 40amp automotive relay and any old switch to operate the relay. That's what i use on my little 500w inverter that just runs the washing machine.
    Edit, before anyone mentions it I do realise a 500w inverter can draw more than 40amp, but this is for a specific purpose and never draws more than 25a.
  9. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    Nope...300 watts at its full potential will draw 25 amps.
    25amps through a 6amp switch is asking for a fire.
    75 watts will be the switches absolute limit
  10. Welsh girl
    Nov 7, 2009
    2,794
    1,361
    living the dream.
    Thanks for the replies. I'll get another switch or an isolator.
    Definitely glad I asked.
    Thanks again guys.
    Saved our bacon, literally! !!
  11. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,929
    6,828
    West Sussex
    No it's not that is the AC rating the DC rating will be about 1 amp.
