Help !!! Newbie in trouble Chausson Flash 03 230v issues (1 Viewer)
linuxyeti
7
Wolverhampton
Newbie
Hi All
Newbie here, we have just got a 2009 Chausson Flash 03, and it's really nice, arrived onsite last night, and everything worked fine. However, must have done something silly today, not sure what.
THe mains hook up is not working as it should, the 230V breaker a CBE-120DS appears all fine, and the fridge is working off the mains, however, the 3 ping plug sockets and abttery charger are now not working. I'm sure it's going to be something simple to to those of you experienced people.
The base vehicle is a Ford Transit
The 230V breaker/switch is a CBE DS-120S
The main fuse box is a a DS-300
Control panel is a PC 150TR
If anyody can help, I would really appreciate it.
Tony
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
And make sure all the 240v breakers are flipped upwards!:Smile:
L
linuxyeti
7
Wolverhampton
Newbie
Tried that, no joy, alas, no power to the 240V plug sockets either? :(
Tony
That's if you do mean, the CB-516 battery charger?
L
linuxyeti
7
Wolverhampton
Newbie
I can only see the 2 on the DC-120s, and they are both linked, and both are in the up position, or are there any other MCB's elsewhere in the motorhome?
Tony
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
It's normal for Chausson to put the 240V distribution box, 12V distribution box and charger all together.
Are you SURE the fridge is running on 240V?:whatthe:
It sounds more like the MCB on the EHU post has tripped!
1948
444
49
surrey
hymer A class
since 2010
Check hook up station fuse just a thought
L
linuxyeti
7
Wolverhampton
Newbie
Yes, the fridge is working off the 240 V hook up, as it switches off when the hook up cable is unplugged, and also when I switch the MB's off (down) on the D-120
Tony
Mar 25, 2013
1,274
39,575
Maidstone Kent
Dethleffs Esprit 160
Since 2013
HiWe had a similar problem on our first time out in the bus.
Our problem was that we hadn't turned the connector in the hook up to switch on the power! We didn't find out til we tried to use the 3 pin socket the next morning. It was our neighbour who came and put us right!!
Felt right numpties but it's all a bit of a learning curve!! :Doh:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
OK it sounds like you have covered it all!:Sad:
Sadly I will bow out with my tail between my legs. I would need to be there with a multimeter to diagnose this one!
Good luck!
L
linuxyeti
7
Wolverhampton
Newbie
The 240V sockets were working fine, but aren't now, must have done something silly !!!
Tony
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
The CBE 240V cables are all linked at a little grey junction box screwed to the floor under the kitchen cupboards I think. They are only connected by small 3 pin nylon plugs. Have you been under the kitchen units and inadvertently pulled a cable out?
Last ditch suggestion!
-Jon
Tarbet Balfour
Belfast
Motorhome Chausson
since 2011
Hi All
Tony
Hi All
Tony
Tarbet Balfour
Belfast
Motorhome Chausson
since 2011
Tried all the options on this thread to solve this problem... Eventually tried this and it worked. Mine was an intermittent fault over three years.
Firstly disconnect the 240v supply from the motor home this must be done for safety purposes.
Second remove the 240v fuse box cover.
Thirdly below the RCCBs, or common name 240v fuses there is a row of connectors. ONE at a time squeeze in the retaining clips at each end and pull the connector out.
NEXT you will notice a male connector end inside the connector attached to the circuit board. use a very small screw driver, and where you see a cross, at the end of the male connector, splay the tip by inserting the screw driver into both the slits, or alternatively use an awl and insert it into the centre splaying the end of the male terminal. after they are done re insert the connector.
Do this for each connector in turn until ALL are done.
This should do the trick if after all other options have been exhausted. I worked for me. RCCBS trip if there is a poor connection, faulty device, appliance or a short.
TerryL
6,171
8,174
North East
Low Profile
I had a similar problem once - it took a well known m/h dealer 3 days to find it.
I'd managed to slightly pull apart one of the plastic connectors in the under-seat storage locker close to the back of one of the sockets. Couldn't tell just by looking.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
This thread is 4 years old.
If he didn't fix it, he probably sold the van!
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Hi and welcome to FUN . It is unusual for a new member to come on with a solution to a problem. Well done.
As has been said the thread is 4 years old, the OP came on desperate for help in his free posts.
If you want to continue to help others you will have to pay your subs £15 it is the easiest £15 i spend every year.
:hiya2::WelcomeFlag:
