Help Needed (2 Viewers)
BJP114
9
Barrow in Furness
Since 2010
Hi every one I have just bought a swift Bolero with a TV bracket see attached photo could any one tell me where I can get an arm to fit a flat screen TV to it.
Or give me a makers name.
Broken Link Removed
Hope some one can help.:thumb:
Loujess
3,123
3,086
Leeds UK
none
Hi BJP. I haven't a clue but I'm sure someone will come along to with some information. welcome to the forum. :welcomefunster: ::bigsmile:
Ivy
43,329
49,441
I doubt very much you will get the rest of the bracket alone and even more unlikely you will find anything to fit it.
tilt/turn brackets are cheap enough and come in many sizes so look for one slightly bigger than the bit you have and it will cover the existing holes.
voyager 1
92
34
Durham Tees valley
c class Swift voyager
30+yrs
I have a swift voyager with the same fitting on for the tv, the arm was bolted to the tv which was supplied by swift . You didnt say if the Bollero you have is new, as far as i know the tv should come with the motorhome if it isn`t a new van i would try and get in touch with the previous owner to see if they still have it. F ailing that if you have purchased it from a dealer see if they can get one for you from swift if all else fails give ebay a try its suprising what you can get from there.
:thumb:
B
BJP114
9
Barrow in Furness
Since 2010
:thumb:
Thanks for your reply yes it is a 2012 Bolero second hand bought from Todds Preston I will see if they can get me one could you tell me the tv make that swift supplied that might help.:thumb:
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
The make of the television is immaterial as the bracket mount holes are the same on all modern units.
Ideally you need the make of the bracket... However, as mentioned already, I believe you would have to be very lucky indeed to find a company willing to sell half a set up.
As already mentioned, your very best chance would be to ask the dealer to give you contact details of the previous owner and ask them if you can have the rest of the kit ( or at the very least ask the dealer to contact them on your behalf
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Pop down asda and get a swing out arm for £15. Be alot easier. You can secure for travel either with velcro straps or by drilling a hole down through and popping a pin ( or old allen key) down to lock in place
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
We have just bought a new Bessaccar (Swift) there was a bracket on the wall similar to yours I took it off and replaced it with a complete swing arm from the local store, has others have said it was the easy option, In the mean time enjoy your new MH and welcome. Pete :thumb::thumb:
Jun 2, 2010
4,924
11,290
Flintshire
Low profile
since 2010
Broken Link Removed
Hi BJ
I bought two of these units (£15.99 from the link below) I fitted one backing plate in the Moho, the other in my bedroom. I fitted one swing arm to the telly and then I can just move the Telly between the Moho and house as and when required, I had to buy two units because they don't sell the components separately
http://myworld.ebay.co.uk/equip2gardencouk55?_trksid=p2047675.l2559
voyager 1
92
34
Durham Tees valley
30+yrs
Can`t remember what make of the original TV. I replaced it for a 21"led TV ,the arm just unscrewed from the back of the old TV and screwed into pre drilled holes in the new one.I bought my Voyager new in 2008, the package included TV sat nav & reversing camera. Don`t know if these items are supplied as standard now. anyway its still worth going back to the supplier to see if they will help you.
Ron [voyager1]:thumb:
Jan 26, 2010
577
1,493
Conwy, North Wales
Relay self build
The one in your photo looks the one that I have which is made by Vision Plus and is available from some Caravan Accessory shops. (There are others which may not fit your bracket so you need to be careful).
I also bought the spare wall bracket and just move the TV from the van into the kitchen when we're at home.
See the attached link for the various brackets:
http://www.gradeuk.co.uk/shop/tv-wall-brackets/
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
IF YOU CANT HELP DONT REPLY:Doh:
:Eeek:::bigsmile::moon:
have a look for brackets on ebay -same as Martins but half price
Have you tried ringing the dealer he may have taken tv out and forgot to put it back in when selling it to you :Smile:
terry
Jan 18, 2010
538
138
Airdrie Scotland
6 years and 20 years as a tugger
Broken Link Removed
Same Bracket thats in my Bessacarr you will have to buy the complete bracket and it comes with all bits including the wall bracket you will get them anywhere ie Tesco
