Stretto Boy
Our new Auto Sleepers Broadway FB was finally delivered yesterday, after a 6 month wait. I then embarked on the task of trying to figure out out everything works, starting with the heating system.
I hooked the van up to the grid and worked my way through the options on the control panel. It all seemed fairly intuitive and so I set the space heating to work on electricity only, gas only and then conbined. They all worked. Bingo! I should mention that throughout the water heater was set to off, as I have not yet filled the water tank.
I turned the system to electric only and left it to its own devices for a couple of hours. When I returned to have van it was fairly cold, the heating was not working and an exclamation mark symbol was on the display. I could not get it to work and so left it.
I went to the van again this afternoon. At first I could not get heater to work but solved the problem with s bit of random button pushing. Again, I left it to work on electric only for a couple of hours. On returning the result was as before : the van was cold, the heating was not working and the exclamation mark symbol was on the control panel.
Does anyone know what the problem is? I did wonder if it might be some sort of safety cut-off tripping, perhaps as a result of overheating. As it is a blown air system, I can't see that the empty water tanks and the fact that the water heater is switched off can be the cause.
All suggestions gratefully received.
