Help needed with LPG installation
Discussion in 'Tech/Mech General' started by emjaiuk, May 25, 2016.
  1. emjaiuk
    emjaiuk Funster
    Sep 3, 2009
    122
    81
    Hi all. any Autogas/LPG experts around.
    I've removed a Gaslow twin cylinder from my motorhome ready to transfer it to a new one. a Hymer exsisi i. The original installation had the filler in the gas locker but on the new one I want to mount them externally.
    The Hymer gas locker is inside the garage, as is the boiler installation on the other side, I wish to mount two new external fillers in the walls of the MH, one directly into the gas locker and one into the boiler area..
    I was thinking of gettng two new inlets with 8mm outlets, using FARO type polypipe from http://www.lpgshop.co.uk/faro-type-o8mm-poly-pipe-6-meters-kit/, running these two pipes to an 8mm 'T' and then via a 8mm to 3/4 UNF JIC reducer to the original Gaslow inlet pipe.
    Does this sound OK? Is 8mm sufficient for filling? As far as I can see the Gaslow hose are 8mm ID in spite of their large OD. I will of course make sure all joints are gas tight and all pipes and junctions securely fixed.
    Malcolm
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    Nothing wrong with DIY (its your van) but with 2 fillers it will never pass a certified gas Test
    Terry
  3. lorger
    lorger Funster
    Jul 11, 2008
    6,288
    7,743
    Dumfries
    I might have missed it what's your reason for two fillers?
  4. scotjimland
    Jul 25, 2007
    28,934
    25,603
    how come Terry.. ?
    I've seen RVs with twin filler points for the LPG tank...one on either side ..
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    No idea but my mate who does testing refused me one saying I cannot t off and have two filling points
    Terry
    • Thanks Thanks x 1
    • Useful Useful x 1
  6. emjaiuk
    emjaiuk Funster
    Sep 3, 2009
    122
    81
    I want to be able to fill from either side. According to Gaslow it's very common on installations they do on caravans. I'd be surprised if they fit anything illegal.
    Malcolm
    • Like Like x 1
  7. StitchesnFluff
    StitchesnFluff Funster
    Oct 18, 2014
    1,230
    520
    Salisbury
    Neat idea then if it's okay by testers
  8. emjaiuk
    emjaiuk Funster
    Sep 3, 2009
    122
    81
    But does anyone know if my method of doing it is OK assuming two fillers is OK?
    Malcolm
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    I never asked Howard why? I simply took the rear filler out so eliminating the T -It could well have been the T he did not like ? Last time I spoke with him he was due a refresher type course (every 5 yrs or so I think) and he was still insisting that gas lockers should have metal linings as per 5 yrs ago -When I pointed out that Autotrails etc don't do metal gas lockers and seam to pass gas checks he simply smiled and said not by him they don't and as far as he knew there has been no change in gas practice as yet -Make of that what you want and remember it is your van and you can do what you want to it any way you want so if it is good enough for gaslow it is probably good enough for you :LOL:
    terry
  10. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,615
    22,774
    Narrfoook
    I spoke to Darrell about this Terry ( as I mentioned he has his ticket for lpg as well as domestic )
    It seems there are THREE sets of rules..
    One for LPG domestic
    One for LPG vehicles
    One for LPG domestic IN vehicles
    Maybe your friend is muddling up between them ?
    Not one of them has a requirement of being in a metal box though for vehicle LPG there is a requirement of a bulkhead of other metal guard between the cylinder and the occupants
    I also mentioned the T to two fillers
    Digging through all the rules and regs it is mentioned.. But only to say care should be taken that using one point will not allow gas to escape from the second.
    As the fillers have check valves in that is not a problem.
    • Informative Informative x 3
    • Thanks Thanks x 1
  11. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    Hi John I assume he only has LPG vehicles - it will be the metal guard/bulkhead bit that he is translating into metal box? Next time I see him he should have had a update course so he may well have a clearer instruction by then because he will have asked for clarification (y)
    thanks terry
    PS no need to remind me of your shelve I remembered;)
  12. Jaws
    Sep 26, 2008
    18,615
    22,774
    Narrfoook
    Nice one !!! Cheers mate
