Help needed with Cruise Control
Discussion in 'Motorhome Accessories' started by emmitdb, Feb 5, 2014.
  1. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,938
    1,816
    Cornwall
    Greetings All,
    Got our 'new'? van back to Cornwall in all the wind and rain but there is an issue.
    I tried throughout the whole journey to get the Cruise Control to work without success.
    We have CC in our car but this one is minimalistic to say the least when it comes to assistance on the stalk.
    I'm going to try to describe it and if I'm lucky I'll post pictures!
    Here goes; The stalk is on the left side of the steering column. It can be pushed up or down, towards me and away from me and it returns automatically to it's original position.
    On the end of the stalk is a microswitch marked "I & II" In the middle of the stalk facing the driver is a triangle (pointing up), with a 'plus' sign inside it. In the middle of the stalk at the bottom is a triangle (pointing downwards) with a 'minus' sign inside it.
    Additionally, on the top edge of the stalk, is a triangle pointing away from the driver. This triangle has what appears to be an "l" inside it and on the corresponding bottom edge of the stalk is a triangle pointing towards the driver with a "C" inside it.
    For some reason I am unable to load the pictures sorry, but all assistance gratefully accepted.
  2. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,942
    1,961
    Warwickshire
  3. buttons
    buttons Funster
    Aug 27, 2009
    14,300
    11,593
    Hertfordshire
    Do you not have a manual, normally there is a separate switch that selects or deselects CC, When selected you should have a light on the dash indicating on. It is at this point that the stalk control will operate. Good luck.
  4. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    Push away to turn on(centre symbol should then light up, if not that explains why its not working)
    Pull to disengage.
    Up to set or increase speed
    Down to resume or decrease speed
    1 & 11 on the end are for pre-set speeds, press to go to that speed,press & hold for a beep
    to set a new speed.
    • Like it Like it x 1
  5. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,938
    1,816
    Cornwall
    Greetings Again,
    I just knew I could count on the Funsters.
    JeanLuc, you were spot on. In fact, looking at the various images, one of them was from Bridgewater Electronics and, knowing the history of the 'van, It's possible the unit came from there.
    I've been out to the 'van as suggested by Jay and the centre button does indeed light up when the engine's running and the unit is put 'On'.
    I'm no technophobe but trying to get a CC on when driving into a gale in the rain on the M5 is not recommended. I've printed out the operations for the next time I'm out. No doubt it will come as second nature in time.
    Thank you all once again.
  6. golly
    golly Funster
    Aug 16, 2009
    1,222
    2,155
    Co Durham
    I had same setup on previous van. the above instructions are spot on.
  7. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,695
    1,495
    West Midlands
    If it's any help I can email you the operating instructions (includes pictures)
    Send me PM with email address.
    To do this click on the username: WynandJean
    Wyn
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,261
    17,928
    YO11 2BD
    i have cruise control :thumb:
    [​IMG]
    • Like it Like it x 4
  9. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,695
    1,495
    West Midlands
    Aha! I remeber that, the Mark 1 version.
    Wyn
  10. pappajohn
    Aug 26, 2007
    30,261
    17,928
    YO11 2BD
    speed control adjustment for the aforementioned cruise control
    [​IMG]
    simply place a diifferent sized marble under rhe pedal to set the speed :thumb::Laughing:
  11. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,695
    1,495
    West Midlands
    Oooh, the high-tec version!
    Wyn
  12. Popeye
    Popeye Funster
    Sep 5, 2011
    8,001
    18,344
    New Forest
    Jay has it "Bang On" I would simply add
    Push away to turn on / Push away to turn off
    Pull towards you to disengage / or to re-engage at the last set speed
    Up to set speed or to increase by 1mph
    Down to Set speed or reduce each time by 1mph
    :thumb:
  13. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,642
    5,705
    Yr Wyddgrug
    I thought it was a 1/2 mile adjustment per movement of the stalk. But I'm only 1/2 sure:BigGrin:
  14. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    585
    386
    Cotswolds
    I think most CC have this nudge feature, even if its not documented and I believe its 1km/h so about half an mph.
  15. pappajohn
    Aug 26, 2007
    30,261
    17,928
    YO11 2BD
    both my car and RV have the 'nudge' feature and definately 1mph increments....unless the stalk is held then its acceleration until the stalk is released.
    The RV has steering wheel mounted buttons but add up to the same thing.
    Probably on european l/h/d vehicles it could be 1kph increments as the speedo would originally be in kph
  16. DP_JAY
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    Ours is 1MPH or hold the nudge for a second (up or down) for 10MPH.
  17. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,642
    5,705
    Yr Wyddgrug
    From my documentation:
    3. KM+ (accelerate). When the Fix/KM+ button is held in when the cruise control system is active the vehicle will accelerate until the button is released. The vehicles speed will be maintained at this new increased setting. This button also provides a "tap up" feature whereby each short press of the button will increase the vehicle's speed by aproximately 1/2 mile per hour. 10 clicks in quick succession will raise the speed by about 5MPH.
    Thank heaven, I was beginning to think I'd imagined it.:Doh:
