Help needed vitron inverter/charger (1 Viewer)
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
Hi can anyone tell me what I have bought and explain what it does please ---PAUL is not around and I cannot wait for him ::bigsmile:Ii HAVE BOUGHT THE WHOLE CABOODLE BUT GRABBED THESE BITS FOR NOW
ESPACHER 4.5 KW DIESEL water heater that also delivers hot air heating -I think or some form of rads heating
7 day timmer
and this victron sine wave inverter.charger unit -no idea on this because it is fed by 240v in att to a single 95 amp hr battery but nothing 240v out on the whole unit
it's out of a ministry road side dipping unit
Once I get all the cupboards etc i will be able to see how things work but hey I am inpatient:Eeek: so thought some of you guys would know something about it all :thumb:::bigsmile:
terry
funflair
19,294
30,058
Guisborough
MORELO palace
since 2012
Hi Terry
It's one of these. http://www.victronenergy.com/inverters-chargers/multiplus-12v-24v-48v-800va-3kva/
Battery charger
Inverter 1200watt with automatic changeover from hook up to inverter power in the event of hook up power failure.
And as I understand it the ability to boost the site hook up amperage by adding the battery powered inverter 240volts to the hook up amps.
All in a nice bit of kit.
Martin
haganap
12,754
26,414
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Taking the light show at Camper Jam a bit far arn't you Terry :winky:
scotjimland
2,246
9,759
A Woosh bang
I fitted the Victron in my RV , bought it from Karl ,
It is a charger, and inverter in one box.. and much more .. fab bit of kit ..
plenty info on Victron site
Also shows the remote control panel.
The EasyPlus is a multifunctional energy system consisting of a powerful sinewave inverter, a sophisticated battery charger, a high speed AC transfer switch and AC distribution in a single light weight and compact enclosure. The system has been designed for those who want to enjoy the comfort and freedom of a complete energy system without spending time on the installation of separate components and difficult technical procedures.
Terry
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
::bigsmile: Thanks guys :thumb: I knew it was expensive but could not figure out it's exact use ::bigsmile: still cannot :winky: but Paul will :thumb:-The benches alone are worth what I paid for the whole lot along with the heater/water combi thing --ended up with 3 water pumps and two 4 gall water tanks and one full of contaminated diesel plus another pump for the diesel loads of thick cables 2 electric trip units that the Victron thing plugs into and lots of other bits --ALL I NEED NOW IS A VAN TO FIT IT ALL INTO :Doh:::bigsmile: plus sell the bloody Transit to release funds to buy one with ::bigsmile:
terry
Terry
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
At this rate I will have to start looking at SOLAR PANELS NEXT :Doh:::bigsmile:
No light's Paul :winky: you and Mick will have to fight between yourselves for that title :thumb:
It's all going into the garage :Doh::Doh::Doh: for MY new van when I do it ::bigsmile:
terry
andy63
4,672
15,017
south shields
None
since 1990
how do you do it????? you will have to teach me.. only bargin I can ever remember getting was some power steering for my old transit, and on reflection that was most probably nicked :Eeek:
that looks similar to the heater I fitted into my van..
ta andy
Aug 6, 2013
11,950
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
7 day timmer
terry
For the inverter:
http://www.victronenergy.com/manuals-per-product/?productid=145
For the Eberspacher:
http://www.espar.com/download-center/truck.html
Espar = Eberspacher in Canada.
Terry
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
ta andy
Hi Andy a case of who you know more than what ::bigsmile:Wait until I get the rest and take a pic or two :thumb:
I normally only put new stuff into the vans but in this case for my own I will make an exception :winky:::bigsmile:
terry
Terry
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
Here are a few pics of the unit that everything was fitted in so now they will become garage units eventually --Paul's been down to look but cannot get to see much so we are eventually going to fit everything back into the units so we /he knows whats wired to what ::bigsmile: then remove it all ready to go into a van :thumb:
terry
Terry
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
a few more pics
May 29, 2013
2,589
19,161
Tyneside
Chausson best of Flash 10
Several years now
Hi Terry
Battery charger
Martin
We don't use that type of inverter at work, but a couple of general points which you may not have considered.
If you plug in the unit to 240v it will give 240v out of its socket. In the event of a power failure it will continue to give 240v for a length of time dependant upon the load and the size of the batteries it is running off. (Ours run from a battery bank the size of a washing machine). However, ours, and possibly yours, have an audible device to let you know the mains has failed. Hence if you pull the hook up you may have to reset this audible device, if it will let you, each time.
Also, check if the DC output is 24v or 12v before connecting anything. Ours give out 24v.
