Help Needed Please
Discussion in 'Solar Power' started by maddy1, Aug 4, 2015.
  1. maddy1
    maddy1 Read Only Funster
    Oct 2, 2013
    38
    9
    Suffolk
    I will try and keep my request short, as i have a problem explaining my self, ok I need help with my solar install, I have an old motorhome and I want to install 6X 100W 12V panels that I've already bought, I'm thinking of 6X Trojan T105, Volt 6, AH 225 I've read lots and lots but, some say this and some say that, (I am gathering as much info as possible in written form) i now have brain overload, I would like to know whats the best way to hook all these up, please? (keep them at 12v in parallel?) I know i need a MPPT controller, which one? i looked at a Morningstar Tristar MPPT 45 amp 12/24/48V, but its a lot of money is there a good alternative? Just to add I want to run a fridge freezer, lowest energy that i can find, so i will need an inverter, maybe 12v to 240 2000w pure sine wave? any suggestions? also looking at a Durite B2B 24v to 12v charger. Many Thanks.
  2. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,014
    11,441
    E Yorks
    That's a heck of a lot of solar panels! What MH have you got?
  3. MikeD
    MikeD Funster
    Dec 21, 2011
    2,136
    1,871
    London
    Bump
  4. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,643
    3,153
    East london
    5th wheel going by his profile
  5. maddy1
    Oct 2, 2013
    38
    9
    Suffolk
    Hello, i used to have a fifth wheel but not no more big mistake on my part i had to sell it and lost a big chunk of money, but that's past now. I now have an old daf 45 7.5 ton that was converted by someone years ago, that i bought about a month ago, i store it at another location about 20 miles away from where I live, so working on her is a bit hard, i've just found a load of damp in the front part on the luton part, and the water heater has a leak under the seat, it seems i've made yet another mistake, but hay ho i'll not dwell on it, this is motorhome fun after all lol
  6. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,604
    2,585
    Tunbridge Wells
    That's a hell of a bank of panels and batteries. The panels need to be wired up in parallel. The batteries are each 6V so I guess they need to be wired up in pairs is series (to make 12V) and then each pair is wired up in parallel. But never having used 6V batteries I am not sure!
    Can't answer on MMPPT controller. When I fitted my solar panels (only 2 x 100W) I used a Schaudt controller because it was compatible with my existing Schaudt Electrobloc.
    I am not sure that even 6 panels are going to produce enough power in the UK to reliably run a standard fridge freezer (or are you talking about a compressor model?) as well as all the other bits and bobs you will use.
    • Like Like x 1
  7. maddy1
    Oct 2, 2013
    38
    9
    Suffolk
    I'm hoping to be in sunnier parts of the world for most of the tiime, as for the fridge freezer im looking at those new ones with Digital Inverter Technology.
  8. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,108
    6,700
    Spain for the winter
    Maddy1 - I would repost this under the title solar/battery help needed if I were you. I think you will get the attention of the members that know all about this stuff then. Worth a try anyway, as the way you are aiming to power your habitation is a little different to most euro vans.
    • Like Like x 1
  9. maddy1
    Oct 2, 2013
    38
    9
    Suffolk
    Ah yes that does make more sense to change the title, it's the problem i have i can't see it unless someone points it out, its just a bit of brain damage from about 40 years ago that i have to live with, thanks for pointing it out, can i edit the title or would i need to start new post?
    I just realized you can't change title so new post it is then, thanks
  10. Armytwowheels
    Aug 10, 2012
    4,108
    6,700
    No you are right you cannot edit a title, but you could just copy and paste your original text, save all that typing.
  11. maddy1
    Oct 2, 2013
    38
    9
    Suffolk
    That's a good point im now trying to do it on my phone its a bit difficult but i don't give up i'll keep trying till i work it out lol i love this predictive text help with my spelling it's not that i can't spell i just need to see it if that makes any sense lol thanks for help
    • Like Like x 2
  12. Minxy Girl
    Aug 22, 2007
    10,014
    11,441
    E Yorks
    I'm a bit concerned about the fridge freezer you're proposing to buy, I know that standard domestic ones are a lot cheaper than a MH specific one however a MH specific one is meant to be in a moving vehicle and IMV will be a bit more resistant to the bumps/holes/movement of the vehicle than a domestic one would be which is meant to be totally static.
    • Like Like x 1
  13. maddy1
    Oct 2, 2013
    38
    9
    Suffolk
    You have a point there MinxyGirl, and one that i over looked, but i think as long as they keep upright and not laid down (best make sure its strapped in) it should be ok, and also i'm going to go be driving real slow in this old girl. thanks for the heads up.
  14. Minxy Girl
    Aug 22, 2007
    10,014
    11,441
    E Yorks
    ... I still think it will be a mistake as they aren't usually 'running' whilst in transit so apart from the above, you could find a fault develops and could even be dangerous. I suggest you'd be better off going for a cheaper / second-hand 'purpose made' MH fridge.
  15. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
    Personally I think your fears are unfounded.
  16. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,865
    roche cornwall
    i have taken house hold fridges all over the place in my trailer up mountains across the desert . possibly far rougher roads than any normal m,home ever gets . most of my friends also use them . they are far stronger than the m,home ones .
    they can be on quite severe slopes and work . even in over 40c temps they work great. compresspor fridges rule . i have also taken an under counter fridge freezer it worked great,.gone back to just a fridge with small freezer compartment but if going with someone else can just change back to fridge freezer. pull out push in . easy.
  17. maddy1
    Oct 2, 2013
    38
    9
    Suffolk
    MinxyGirl, The compressor type domestic fridge freezers, are just that, a compressor, with refrigerant running around them, so nothing to worry about, the only time you need to let them rest for 24 hours is if you every lay them on there side to move them about, its so the refrigerant can settle before turning it on.
