Help Needed, Norcold Fridge/Freezer N611RT
Discussion in 'Motorhome Chat' started by Brightspark, Oct 7, 2012.
  1. Brightspark
    Brightspark Funster
    Dec 27, 2010
    240
    108
    Northallerton , North Yorkshire
    Hi All, my fridge/freezer has decided not to run on 240V. The green 'ON' light is lit but the unit will not go cold. All ok on gas. Any idea's ? Thanks
  2. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
    Not familiar with that particular model but it sounds like the element has gone, it should be easy to fix if it is anything like a dometic / electrolux you basically need to remove the insulation around the flue and there should be two elements fitted to the side of the pipework one for 12v one for 240v
  3. FULL TIMER
    May 31, 2012
    796
    712
    NORWICH
    just noticed you have an RV, so I assume your fridge would be fitted with 120v element. while you are checking your fridge it might be wise to google norcold/ dometic/ thetford recalls as a recent thread I came across possibly on this forum or maybe the RVOC forum was about a fault with some fridge cooling units overheating cracking and leaking the refridgerant gas out and catching fire, the poster lost his RV and belongings.
    found it see here; http://www.rvoc.co.uk/forum/rv-general-chat/3883-rv-fire-warning.html
  4. Brightspark
    Brightspark Funster
    Dec 27, 2010
    240
    108
    I am as we speak searching the other site for info. Thanks
  5. Brightspark
    Brightspark Funster
    Dec 27, 2010
    240
    108
    Norcold Fridge problem resolved.
    Just to let you all know i have managed to resolve the problem with the fridge not cooling down on 240volt. Well it didnt cool down on gas either & i was surprised i didn't get more responses to my original request for help, but 'hey ho' thats the way it goes sometimes!
    Now here's a tip for you all, i assume funsters don't know of this one 'cos no-one mentioned it but it helps to have your unit level.
    I managed to download the manual & it states it only has a tolorence of 3 degrees side to side & 6 degrees front to back.
    I know what you are all going to say, well thats obvious! 'school boy error' Yes it probably is but when you are full timing you don't realise that the unit is slightly leaning.
    So all is now level & the fridge is COLD !!
  6. FULL TIMER
    May 31, 2012
    796
    712
    NORWICH
    Ah but you tricked us, in the first post you did say all was ok on gas, still glad you got it sorted it's not nice when things play up
  7. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,231
    16,821
    Liverpool.
    I don't want to dampen your spirits but my guess is it wont be staying cold for long. The damage has been done.
  8. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    if you had posted the issue on RVOC
    If you had posted your issues on RVOC then I am sure one of the many American owners on that site would have responded.
    While there are many members on MHF with an RV there are more on RVOC. Most owners would have called Duncan of Star Spangled Spanner in Lincoln as the first port of call with an issue with a fridge/freezer.. he is the man that knows all the issues re these kind of problems.
    Horses for courses.
    Bob
  9. Brightspark
    Brightspark Funster
    Dec 27, 2010
    240
    108
    I did call Duncan & he confirmed that would of caused the problem. The fridge is now keeping a constant temperature of 2 degrees c. & the freezer
    -3c
    I did search the RVOC site for threads to 'problems with fridges' but could not find anything that highlighted the symptoms that i was experiencing. I also prefer this site!!
    Thanks for all your comments.
