Help needed locating fuse for 180w dashboard outlet
Discussion in 'Tech/Mech General' started by redpis, Mar 29, 2009.
  1. redpis
    redpis Read Only Funster
    Mar 8, 2009
    24
    I have a CI Motorhome carioca 656, adjacent to the cigar lighter is a socket marked 180w, this outlet has no power to it, I have tried all the fuses I can find (behind drivers seat, in the dashboard fuseboard and under the bonnet) anyone know where the fuse lives?
    It might be that the fuse has been removed, if so that would throw me completely as I have checked for conitinuity on all fuses in their holders.
    I don't even know if this outlet is only live with the ignition on or off, or for that matter where does it derive its feed, leasure or cab battery.
    Sorry for the long post.
    Ian
  2. scotjimland
    Jul 25, 2007
    28,936
    25,588
    Hi Ian ,
    if it's original base vehicle fitment then it will be fed from the engine battery and probably only live when ignition on.. it may have an in-line fuse behind the socket.. or in the socket base, should be able to pull it out for checking if you cannot access from under the dash .
    hth
    Jim
  3. redpis
    Mar 8, 2009
    24
    Sorted :)
    Cheers Jim,
    I thought, right! this panel coming off so was about to start the attack from the passenger side and noticed a fuse cover exactly the same as on the drivers side, took the cover off and low and behold, another fuseboard.
    Counting from left to right, fuse 7 was missing, belled-out the fuse blade connection to the centr of the outlet and bingo!!, inserted 15A fuse and all is well.
    Ian
