Help needed for window leak (1 Viewer)
TheWM
445
450
London
Rapido 9010df
Newbie, but over 10 years in a campervan
hi guys,
On holiday and woke up to soggy duvets today. Got a leak on the rear window. We can see where it is coming from.
If I cannot get sikaflex to repair, any ideas on what I can use that I can buy in a b&e or similar? Is there a guide somewhere that someone can point me to please?
Bit of a dampner!
Feb 24, 2013
13,078
101,442
Bolsover, Derbyshire
Hymer S800
not long enough
Gaffer tape on the outside of the whole window frame, wait till home get it resealed then, when the window can be removed and check for where the water is getting in
At the moment you only know where it is coming out (y)
Rob and Val
1,906
2,677
Lincolnshire
Talbot Compass Calypso
Since July 2010
We had exactly the same thing happen on a side window in June when we were in the Mosel! As DavididG58 said, we used gaffer tape as a temporary measure until we got home. Back home, I couldn't remove the window, so put a new seal around the outside of the window with this: -
Ber090
807
2,560
West Yorkshire, UK
Autosleeper Warwick
Since 2012
The Gaffer tape solution will be probably your best bet till you return home. You will be able to get it dry enough to stick. Sealant will struggle to adhere unless you use a specialist under water type.
Good luck
Bernie(y)
Jun 22, 2012
231
130
Ebbw Vale Gwent
Rapido 9048df A class
seven
Try to see if it is coming in though between the glass and the frame or from around the frame itself. if its from the frame you will need to take the frame out and clean and reseal it, this is not as hard as you may think, as long as you take you're time and you have the tools, screwdriver with changeable head a sealant and sealant you will be fine.
TheWM
TheWM
445
450
London
Rapido 9010df
Thanks guys. With my leg being what it is I haven't looked at it yet. En route to Weston super mare where hopefully it will be drier and we can put on a temporary gaffer solution. Was thinking plumbers mate or similar on the inside?
TheWM
TheWM
445
450
London
Rapido 9010df
@Hydrocell from what my missus has told me, there is water pooling around the inside of frame (externally). Will investigate further when we stop.
Badknee
7,407
412,580
notloB
Vantage Neo
Living the dream.
The problem won't be at the bottom it will be at the top or higher up that the bottom sill I would think. A mighty pain in the bum in this damp weather to get it dry enough to re-seal.
Reactions: GJH
TheWM
TheWM
445
450
London
Rapido 9010df
Here's what I managed to do missus can finish it later as I can't reach with my dodgy leg.
D
Deleted member 29692
Don't put anything on the inside. If your temp repair on the outside doesn't hold you're better off with the water coming into the van where you can see it and clean it up than it coming in and getting trapped between the inner and outer skins where it will end up soaking the body of the van doing damage you might not notice until it's too late.
Reactions: GJH
Jul 29, 2013
9,071
18,506
Salisbury
Hymer B678DL A class
since 2011
STIXALL is pretty good you can use it even when it's wet and it will seal it.
madgeD
259
480
Cleveland
Van conversion
since 2005
When we had this problem with a newish caravan we had to replace the rubber all around window, a Dealer not the one we bought the van from contacted the maker and managed to get us the rubber free of charge , hubby and I managed the job on our own.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Had this problem on both side windows in Greece and stopped for the remaining 4 weeks of the trip using gaffer tape as mentioned. Windows renewed by Autotrail on return under warranty though van was over a year old. As said, DO NOT seal the inside, but do seal the complete window surround till you return.
Good luck.
TheWM
TheWM
445
450
London
Rapido 9010df
Hi guys - back from hols. The leak was more or less sorted by putting gaffa on the outside of the window (albeit, there was one or two drips coming through, but 95% less water at least). So, now I'm back. How do I go about fixing the window..?
I have a friend who does double glazing who is happy to help me, if I can tell him what needs to be done. I'm assuming, remove the window and sikaflex the seal?
So, how do I remove the window, inspect and seal? And are there other things I should be considering (i.e. whether I need a new rubber seal?) The van is 6 years old.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The inner & outer parts of the window squeeze the van wall between them. Undo all the inner screws (they may be hidden under trim caps) whilst your helper outside the van leans gently on the window to stop it falling out. Remove inner frame then from the outside remove the window. If it is stuck to the van wall it may need gentle pressure from the inside or the use of a broad plastic kitchen spatula to free it. Clean off old sealant - white spirit will clean off remnants - then allow window cutout to dry if still wet. Use the type of mastic linked below this message. Do not use Sikaflex (the variety most people mean is a polyurethane adhesive which will make an excellent seal but will also prevent future removal of the window). No sealant should be used inside the van.
Broken Link Removed
............... which is also available in various widths from most caravan / MH accessory shops.
TheWM
TheWM
445
450
London
Rapido 9010df
Broken Link Removed
Thanks for this - appreciated.
A couple of questions:
Am I right in thinking that the mastic will be placed over the rubber seal and then pushed into place?
The width of the tape, can I tell what width is required, or is it a case of removing the window, measuring the seal and then going with that?
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
they should be fitted on non setting mastic ribbon tape dont use silicon of any sort as they are very acidic and can cause corrosion problems
TheBig1
17,630
43,239
if you use 20mm mastic and its too wide, you can just trim off the excess with an old credit card etc. it always oozes a little anyway just dont be tempted to overtighted the screws and force all the mastic out
funflair
19,338
30,196
Guisborough
MORELO palace
since 2012
If the gaffer tape virtuall cured it suggest the water is coming between the window plastic and the seal and not between the window frame and the van, it will be worth checking that the drainage channels are clear.
And gaffer tape can be an absolute sod to get off after some time so don't leave it any longer than needed.
Martin
TheWM
TheWM
445
450
London
Rapido 9010df
@funflair my missus said that she thought it could be a blocked drainage hole due to how the water was pooling. How do I inspect said drainage hole?
funflair
19,338
30,196
Guisborough
MORELO palace
since 2012
There should be a couple of little slots in the bottom of the frame, just poke them clear.
Martin
Jun 1, 2009
77
98
middleton manchester
coachbuilt
6 years
if you have a high level brake light above window clean old seal out and reseal,had a problem on my autotrail like this and it was the high level light that was leaking and running down to the window.
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Hi get some Puraflex 40 from toolstaion and simply let your mate mask up (1 to 2 mm) all around the outer edge of frame and van then seal it all up-smooth with wet finger remove tape and clean off any access with frame cleaner -No need to remove window -They are sealed with a rubber gasket that should be renewed when taken out but I don't know anyone who does this
They simply remove window ,clean and put sealant around(either tape or mastic gun type) then refit and clean off excess :LOL:doing exactly the same job as your mate with masking tape ;)then charge you a small fortune :(:LOL:
BTW even on new windows that have rubber seals we still stick them in with Puraflex 40 and clean off simply because with PVC they get odd shaped side with slight bends in them so don't trust the rubber gasket to make the seal (y):D
If it's leaking on the inner gasket to perspex window(glass) then a black single sided draught excluder tape stuck to the gasket can be used until a new gasket can be bought -the new gasket simply pulls out and pushes into the groove but we find the draught excluder works and most don't bother to order a new gasket :D
terry
Reactions: GJH
TheWM
TheWM
445
450
London
Rapido 9010df
Cheers @Terry.
To be honest, that is what he suggested as a first fix. I was tempted with taking the window out, if only to increase my knowledge of doing such tasks, but whilst I'm brilliant at taking things apart, the same can't be said about putting them back together.
My missus has also recalled seeing the drainage holes @funflair so we will be inspecting them later today with something appropriate to push through them.
TheWM
TheWM
445
450
London
Rapido 9010df
So - got out today to look at the drainage holes first as suggested by @funflair one was definitely blocked at the same side of the leak and we cleared the gully which was full of crud. As you can see from the pics there is some kind of black sealant around the frames. Does anyone know if this is factory sealant or has someone added these due to a leak previously? I sprayed a hose all around the area after cleaning and on initial inspection no water coming through :) should I go ahead and seal to be on the safe side and if so should I remove the black stuff in situ or just go over it?
funflair
19,338
30,196
Guisborough
MORELO palace
since 2012
Looks like original factory non setting mastic with a bit of mould to make it black, I did around ours a couple of months back, just carefully take it back to the frame edge and the go around with the non setting stuff finish it with a cloth and white spirit, if nothing else it will look better.
Martin
TheWM
TheWM
445
450
London
Rapido 9010df
Thanks Martin, and to everyone else that has contributed. Very informative information that I couldn't get elsewhere :)
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
That's the factory tape mastic ;)JUST shows how much faith they have in the window rubber seal ;)I also have little faith in the rubber so do as I said in my other post
terry
Reactions: GJH
TheWM
TheWM
445
450
London
Rapido 9010df
terry
Understood ;)
