Help needed for window leak
Discussion in 'Motorhome Chat' started by TheWM, Aug 31, 2015.
  1. TheWM
    TheWM Read Only Funster
    Feb 24, 2015
    445
    450
    London
    hi guys,
    On holiday and woke up to soggy duvets today. Got a leak on the rear window. We can see where it is coming from.
    If I cannot get sikaflex to repair, any ideas on what I can use that I can buy in a b&e or similar? Is there a guide somewhere that someone can point me to please?
    Bit of a dampner!
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,324
    34,781
    As a temporary measure, you could put a thick bead of sealant round the outside to deflect rain.
  3. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,443
    12,606
    Bolsover, Derbyshire
    Gaffer tape on the outside of the whole window frame, wait till home get it resealed then, when the window can be removed and check for where the water is getting in
    At the moment you only know where it is coming out (y)
    • Like Like x 2
  4. Rob and Val
    Rob and Val Funster
    Oct 17, 2010
    878
    2,136
    Lincolnshire
  5. Ber090
    Ber090 Funster Life Member
    Dec 12, 2012
    491
    491
    N Yorks
    The Gaffer tape solution will be probably your best bet till you return home. You will be able to get it dry enough to stick. Sealant will struggle to adhere unless you use a specialist under water type.
    Good luck
    Bernie(y)
  6. Hydrocell
    Hydrocell Funster
    Jun 22, 2012
    176
    112
    Ebbw Vale Gwent
    Try to see if it is coming in though between the glass and the frame or from around the frame itself. if its from the frame you will need to take the frame out and clean and reseal it, this is not as hard as you may think, as long as you take you're time and you have the tools, screwdriver with changeable head a sealant and sealant you will be fine.
  7. TheWM
    Feb 24, 2015
    445
    450
    London
    Thanks guys. With my leg being what it is I haven't looked at it yet. En route to Weston super mare where hopefully it will be drier and we can put on a temporary gaffer solution. Was thinking plumbers mate or similar on the inside?
  8. TheWM
    Feb 24, 2015
    445
    450
    London
    @Hydrocell from what my missus has told me, there is water pooling around the inside of frame (externally). Will investigate further when we stop.
  9. Badknee
    Badknee Funster
    Aug 25, 2014
    3,708
    15,892
    notloB
    The problem won't be at the bottom it will be at the top or higher up that the bottom sill I would think. A mighty pain in the bum in this damp weather to get it dry enough to re-seal.
    • Like Like x 1
  10. TheWM
    Feb 24, 2015
    445
    450
    London
    Here's what I managed to do missus can finish it later as I can't reach with my dodgy leg.
    • Like Like x 1
  11. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,566
    11,461
    Kettering
    Don't put anything on the inside. If your temp repair on the outside doesn't hold you're better off with the water coming into the van where you can see it and clean it up than it coming in and getting trapped between the inner and outer skins where it will end up soaking the body of the van doing damage you might not notice until it's too late.
    • Like Like x 1
  12. Speve
    Speve Funster
    Jul 29, 2013
    2,029
    1,751
    Salisbury
    STIXALL is pretty good you can use it even when it's wet and it will seal it.
  13. madgeD
    madgeD Funster
    Aug 17, 2014
    255
    467
    Cleveland
    When we had this problem with a newish caravan we had to replace the rubber all around window, a Dealer not the one we bought the van from contacted the maker and managed to get us the rubber free of charge , hubby and I managed the job on our own.
  14. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,871
    1,624
    Bungay Suffolk
    Had this problem on both side windows in Greece and stopped for the remaining 4 weeks of the trip using gaffer tape as mentioned. Windows renewed by Autotrail on return under warranty though van was over a year old. As said, DO NOT seal the inside, but do seal the complete window surround till you return.
    Good luck.
  15. TheWM
    Feb 24, 2015
    445
    450
    London
    Hi guys - back from hols. The leak was more or less sorted by putting gaffa on the outside of the window (albeit, there was one or two drips coming through, but 95% less water at least). So, now I'm back. How do I go about fixing the window..?
    I have a friend who does double glazing who is happy to help me, if I can tell him what needs to be done. I'm assuming, remove the window and sikaflex the seal?
    So, how do I remove the window, inspect and seal? And are there other things I should be considering (i.e. whether I need a new rubber seal?) The van is 6 years old.
  16. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,954
    2,776
    Kendal, Cumbria
    The inner & outer parts of the window squeeze the van wall between them. Undo all the inner screws (they may be hidden under trim caps) whilst your helper outside the van leans gently on the window to stop it falling out. Remove inner frame then from the outside remove the window. If it is stuck to the van wall it may need gentle pressure from the inside or the use of a broad plastic kitchen spatula to free it. Clean off old sealant - white spirit will clean off remnants - then allow window cutout to dry if still wet. Use the type of mastic linked below this message. Do not use Sikaflex (the variety most people mean is a polyurethane adhesive which will make an excellent seal but will also prevent future removal of the window). No sealant should be used inside the van.
    http://www.ebay.co.uk/itm/W4-Mastic...Sealants-11-/311400510529?hash=item4880eab441
    ............... which is also available in various widths from most caravan / MH accessory shops.
    • Like Like x 1
  17. TheWM
    Feb 24, 2015
    445
    450
    London
    Thanks for this - appreciated.
    A couple of questions:
    Am I right in thinking that the mastic will be placed over the rubber seal and then pushed into place?
    The width of the tape, can I tell what width is required, or is it a case of removing the window, measuring the seal and then going with that?
  18. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,040
    3,420
    walthamstow east london
    they should be fitted on non setting mastic ribbon tape dont use silicon of any sort as they are very acidic and can cause corrosion problems
  19. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,348
    9,787
    if you use 20mm mastic and its too wide, you can just trim off the excess with an old credit card etc. it always oozes a little anyway just dont be tempted to overtighted the screws and force all the mastic out
  20. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,811
    5,092
    Guisborough
    If the gaffer tape virtuall cured it suggest the water is coming between the window plastic and the seal and not between the window frame and the van, it will be worth checking that the drainage channels are clear.
    And gaffer tape can be an absolute sod to get off after some time so don't leave it any longer than needed.
    Martin
