Help need for query on car brakes
Discussion in 'Tech/Mech General' started by isitfriday, Jul 26, 2015.
  1. isitfriday
    isitfriday Funster
    Apr 17, 2010
    86
    27
    Basingstoke
    Hi,
    This forum has been great for help with all sorts so I'll ask here first.
    I have returned home after two weeks away in Orkney & west highland area. (I'll save that for another post)
    The car a Ford Focus 2009, was on drive for two weeks. I drove it and there is a bad knocking noise when I break, the noise did ease up a bit, the more I drove and used the breaks but it sounded awfull and therefore only went to local shops.
    The car was fine when I left.
    Any ideas?
  2. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    probably the pads / brake shoes stuck to the discs / drums and it takes a short while to clear. a good reason not to over apply the hand break if leaving stationary for a while.
  3. Clewsy
    Clewsy Funster Life Member
    Feb 26, 2014
    64
    76
    On the road
    I had a similar problem with a Skoda left for three weeks. The front discs had rusted and then when the car was used the discs became pitted which caused a significant brake judder. Had to replace the front discs to cure it.
  4. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    You could take it for a drive, and on clear road as you are moving ,gently apply handbrake to get rid of any glaze, then do the same foot brake /accelerate(toe heal) to de-glaze front brake see if that improves it before spending any unnecessary money.
    hope this may help :)
  5. isitfriday
    isitfriday Funster
    Apr 17, 2010
    86
    27
    Basingstoke
    Thanks folks I'll take it out to try out your tips,
  6. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    4,765
    8,951
    Lorca,Murcia,Spain
    Many vehicles these days the electronics won't allow you to do it. On mine if you put your foot on the brake pedal whilst also on the accelerator then after a few seconds the engine light will come on & it goes into 'limp' mode. Take foot off accelerator & all will return to normal.
  7. jollyrodger
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    Ford focus?:) son has a 2014 focus navigator can do it on that
    Ours hyundi 64 plate i30 also cando with gentle pressure as if acc against brake (y)
  8. Zains Pops
    Zains Pops Funster
    Sep 10, 2013
    722
    4,143
    Chelmsford Essex
    Could be ceased caliper,
    Try gentle brake pedal and accelerator as above. Then when stationery apply pedal fully with some force,then drive off. Hopefully it will free up.
  9. MikeD
    MikeD Funster
    Dec 21, 2011
    2,052
    1,827
    London
    I suspect you just have a bit of rust on the discs. As everybody before has said drive around for a bit and brake a lot.
    It should go away reasonably quickly so if it is still doing it after fifty miles I would take the wheels off and have a look. (y)
  10. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,551
    3,361
    Telford, Shropshire
    It is most likely just rust but there is a remote chance of a cracked brake disc, (I had one go overnight on a Renault 5 many years ago) so before you take it out and do the left foot braking bit get the wheels off and inspect the brakes. The way I look at it is this, a problem with engine or transmission and it may not go very well but a problem with the brakes may mean it doesn't stop very well. This leads us to the Dirty Harry question: "How lucky do you feel?"
    D.
    • Like Like x 1
