HELP!!! Michael has blown the 240 fuse! (1 Viewer)
Teasy2007
2,086
1,159
Rotherham South Yorkshire
Carthago Malibu PVC
Hi everybody, could someone please point us is the right direction to find the Autocruse Starburst 240 fuse box.
Michael has blown the fuse and we have no idea where it is in the motorhome. He is turning everything upside down and cant find it anywhere. He has found the main fuse box but that only seems to have fuses for the 12 volt side.
Please help we are in Spain on a campsite and I really dont look forward to spending the next month without electricity.
Ginny
Lenny HB
53,421
149,945
On the coast in West Sussex
Hymer B678 DL
Look at where the mains inlet is on the van and within about a metre of it you should have a consumer unit (grey plastic box which will have an RCD and 1or 2 MCB's, It's a small version of what's in your house).
It's most likely the RCD has tripped (that's the safety device) it will trip if overloaded or there is a fault, the MCB's are like re-settable fuses. Find the box and turn it/them back on, first unplug what may have tripped it.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Pure guesswork says it's very close to where the hook-up cable plugs in.
Also it might not be your fuse but the campsite's.
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
Thanks Lenny, there is a small blue plastic box but you have to unscrew it to get inside so Michael did not want to do more harm than he already has. I will show him your quote and see if that works.
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
No unfortunately, it was definitely us, we blew the whole campsite and when they turned the electricity back on, our was the only one not working.
Ginny
Jim
Ringleader
Jul 19, 2007
36,409
130,847
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Ginny
Hi Ginny, you'll look back at this and laugh, but probably not today::bigsmile: Hope you find that fuse:thumb:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Ginny
Seriously awesome. Well done.
Makes note: Teasy, if going on a meet with these plonkers take generator.
Lenny HB
53,421
149,945
Hymer B678 DL
Wouldn't expect to have to unscrew it, some have a hinged cover most are open to the breakers.
I would expect it to be 5 - 8 inches wide x 8 inches high normally they are light grey you may be looking at the wrong thing.
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Under the passenger seat Ginny, thats where ours is. Slide the back cover off & you will see the RCD with a switch that is tight to push up.
But you should look for what caused it in the first place.
Keith
PS I should have said it's a bit tight to get to, little fingers needed.
dshague
996
302
VAN CONVERSION
20 years
behind either of the seats there should be a flap velcro the fuses are there i phoned
the dealer for you .good look dont kill him .:Doh:
keith
3,421
1,864
Ecclefechan
No, fuses are in a plastic box behind the drivers seat.
Ginny has a similar van to us & of a similar age.
She is not on line at present so wont see these replies, hope they get it sorted soon. :thumb:
dshague
996
302
VAN CONVERSION
20 years
have just text her asking her to look at fun
dshague
996
302
VAN CONVERSION
20 years
Keith just had a text back saying thank you .mike found switch and they are now cooking .
she did not say they were still talking though.:Smile:
keith
3,421
1,864
Ecclefechan
Good result. Glad they got it sorted.
Big Momma
85
Although the RCD box is usually close to the 240v inlet, not always the case. Mine is under one of the bench seats on the opposite side of the van. As already described, grey box with switches like you have at home. Suggest that if not already done so, turn your power buton off before you re-set the trip switch and unplug all your electrical items. this will prevent you from re-blowing the whole capsite again when you switch back on. Do you know what Amperage the site is supplying to you (5A, 10A, 16A) ? Also look at what you have plugged in and anything that you may have added to the load just before it went off. Shouldn't be too hard to find just not always in the most logical place and certainly no screws to remove. Best of luck and hope you get re-connected very soon.
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
Keith
Thanks Keith, David texted your information and we are back in business again. Michael turned the van inside out but could not find it at all. I emailed Marquis and they rang me this morning with the information as well, so I was really pleased, excellent aftersales service!!
As to what caused the problem in the first place - I had asked Michael to extend the kettle cable so we would not have to use the extention. He finally got round to the job and cut through the extention cable whilst it was still plugged into the mains - I am glad to report he was not hurt, but as I reported he managed to short out all the electricity on the site. Still everything is ok now and at least we now know where the trip switch is for the 240!! LOL
Thanks to everybody who came back to me, especially Keith and David.
By the way, the sun is finally out in Santa Suzanna, we have had 3 days of almost torrential rain ( from Sunday to Tuesday) and we are just about dried out!
Ginny
Teasy2007
Teasy2007
2,086
1,159
Carthago Malibu PVC
Hi David, the problem with men is when they make a BIG mistake we women are not allowed to say anything BUT when we make even a little mistake we never hear the last of it!!
PS I was so sorry for him I never said a word and we laughed about it afterwards - do you remember when Michael went dashing under that low bridge with only an inch of space, or the speed bump which broke every glass and cup in the Van. I rest my case!!
Ginny
