Help lights (1 Viewer)
S
stagman
DOES ANYONE KNOW HOW TO GET LENS OFF THESE DOWNLIGHTERS.NEARLY PULLED ONE OFF ROOF TRYING :helpsos:
Link Removed
Can't see it very clearly ,but I think it is the type you prise the diffuser out with a thin screwdriver,you may see a small cut out bettween the body and th d/fusser have a good look all round it, s/driver in and turn should pop out.:thumb:
iceni
300
117
Birmingham
Lowline Coachbuilt
27yrs
I fink its either screwed off (wear a pair of rubber gloves for grip) or the other type is held in to the drilled out hole in the rrof by 2 or 3 sprung legs so will just pull out but be carefull when the sprung legs spring back in case they trap your finger
Phill
Braunston
1,408
7
Hi,
I have lights which look very similar and one of mine fell off, well the outer plastic ring together with the lens, and it just pushes back so i think the careful application of a small screwdriver as suggested above is probably the way to go,
Let us know how you get on, and does anyone know if you can purchase the outer plastic ring separately as mine is cracked that's why it fell off
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
They are the same as fitted into my Swift, Cheap and nasty, I suggest you use a thin bladed knife, use it edge on under the rim and twist the knife, have just taken one of mine off to check that I am correct.
Your biggest problem is going to be getting the B"£$% thins to stay on after the removal, as I said "Cheap and Nasty"
Doug....
43,323
49,437
i would suggest trying to unscrew it before prising it off.
if it does screw on then prising it will damage the thread or the trim.:Doh:
shifter
shifter
67
wee island across pond NI
coachbuild
3 years
Lights
CHEERS ALL
GOT THE WEE FRIGGER OFF
ITS ASNAP ON RING.BUT TO GET IT OFF IT COMES AWAY FROM ROOF FIRST THEN PULL APART WITH KNIFE.
IS THEIR A LED REPLACEMENT BULB FOR THESE DO YOU KNOW OF.:thanks2:
43,323
49,437
i think the LED type of replacement is a circular board with the circuit on one side and the LEDs on the other.
two wire prongs fit in the original bulb holes.
this is one type i've seen but not 100% sure though.
have a look Link Removed
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
The type you usually want is the one called G$ on the previous link. The thicker round one won't fit in most fittings. Also available from ATEN. I have replaced a lot of my bulbs, very useful if you are away from a hookup. Seem to be brighter too:thumb:
