Help I've blown the electrics!!
Discussion in 'Motorhome Chat' started by Coolbeanz, Aug 25, 2013.
  1. Coolbeanz
    Coolbeanz Funster
    Feb 26, 2013
    1,378
    1,944
    Capel St Mary
    I forgot the halogen hob was on and the iPad on charge and plugged my 1200W hair dryer in. No surprise the electrics blew!! Trouble is we can't find the main fuse!! Any ideas. It is a Fiat Elnagh Doral if that helps? To make matters worse the fridge is refusing to work on gas as the ignition switch keeps clicking so unless we can find the fault we will have to eat 2 large bowls of chilli and a chicken curry tonight before they go off! Any help appreciated. :cry:
  2. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,286
    7,985
    West Norfolk
    If your fridge keeps clicking, the chances are-
    a) You've run out of gas!
    b) Your regulator has gone tits up due to blockage and requires replacement!
    Does your gas hob work?
    As for the mains electrics, you will find it will only have tripped at your distribution panel or the hookup post! You just have to find your panel!!!!:BigGrin:
    • Like it Like it x 1
  3. Coolbeanz
    Coolbeanz Funster
    Feb 26, 2013
    1,378
    1,944
    Capel St Mary
    We have plenty of gas so I'm thinking the fridge is buggered. We have checked the main box and its not tripping when we test it so something's wrong. Looks like a trip to a repair shop!
  4. Terry
    Terry Funster
    Dec 27, 2007
    10,770
    6,291
    South yorks
    Hi try unplugging from HU then reseting trip in both van and HU point then replug in :thumb:Also try switching the fridge on and off ,the gas could well be trying to ignite but you may have a little damp around the ignition ---My fridge sometimes does not ingnite first time after its been stood but after a couple of times it fires up,then once its been lit it goes first time :thumb:
    terry
  5. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,760
    10,175
    find your distribution box in the van....generally near to the point where the cable enters the van, but hidden in the back/bottom of a cupboard.
    switch the trips fully OFF, then back to ON
    this of course assumes you checked there is power at the bollard or use a different socket. on some sites ive been on, you need to get the site staff to come with a key to switch it back on
  6. Coolbeanz
    Coolbeanz Funster
    Feb 26, 2013
    1,378
    1,944
    Capel St Mary
    Just out on a lovely cycle ride along the north Norfolk coast so will try every ones suggestions when we get back to the camp. Thank you :BigGrin:
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,112
    17,781
    YO11 2BD
    if the main switch in the vans fuse box doesnt trip when tested you have no power getting to the fusebox.
    one of two things could be wrong.
    you tripped the site hookup posts breaker
    you overloaded the hookup lead and that needs checking for continuity
    can you borrow a lead for a few minutes to plug your van in and see if it then works.
    one more thing.....try plugging into another hookup post, it may be a faulty breaker on the one you are currently on..
  8. journeyman
    journeyman Read Only Funster
    Mar 22, 2011
    459
    390
    NE Wales
    I think every motorhomer needs Pappajohn on speed dial. :Rofl1:
    Hope it gets sorted.
    • Like it Like it x 3
  9. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    The fridge will not ignite if the battery level is too low which I am guessing it will be with things blown
  10. daisy mae
    daisy mae Read Only Funster
    Mar 12, 2013
    676
    596
    Leicestershire
    A couple of times when we were away in the caravan, I switched the electric kettle on, a normal house one, I forgot that we had the electric heating on, well it tripped, the warden sorted it at the EHU post, another time the warden was away, and hubby just plugged in to the other point on the post, told the warden later.no problem, I then put a note on the kettle cable, check fire before switching on, we now have a low voltage kettle, :thumb:
  11. Coolbeanz
    Coolbeanz Funster
    Feb 26, 2013
    1,378
    1,944
    Capel St Mary
    We tried another hookup point when we got back to the site so it's looking like it could be the lead. We didn't like to ask our neighbour as they were cooking tea and watching tv so we will borrow a friends lead when we get home today and try it. To make matters worse the gas bottle ran out just as I finished cooking the curry so no cup of tea for me this morning. Best I get up and get ready for a ride to Sheringham if I want a cuppa!! :Doh:
