Help help
Discussion in 'The Beginner' started by Smurf, Oct 6, 2011.
  1. Smurf
    Smurf Read Only Funster
    Sep 28, 2011
    5
    South Wales
    Got a fiat ducato 1994 royale 540, drove from Bristol to Wales no prob, parked up, tried this morning engine battery deado, battery isn't old, looked on control panel of water n battery readings, when you flick rocker switch to internal power ie lights pump etc all fine and needle in green, switch rocker to cab and it goes to red no lights were left on overnight as I'm pretty careful on that, and I left the rocker switch in middle so nothing could have been left on, as I'm new to this I'm lost, I would appreciate any help thanks.
  2. lorger
    lorger Funster
    Jul 11, 2008
    6,225
    7,652
    Dumfries
    Hi Smurf sorry to hear about your problem i was going to ask if you had it on vehicle battery overnight but it seems not. Have you had a look to see if its a loose connection we had this in France with our boxer. The vehicle battery has a buzz bar (where all the connections are) that connects to the battery we had a loose fitting on it. Do you have lights on on the dash board as its very unlikely that a flat battery wouldn't have any power at all. Im sure someone else will be along soon with more advice.
    Good luck
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,258
    5,239
    East Sussex 01-580-881288
    Do the vehicle lights work, sidelights, headlights, if so could be a bad connection to starter solenoid, if they dont work, dud battery or bad earth.
    Peter
Similar Threads
  1. Dan16
    13
    509
  2. Jasonsmall007
    6
    351
  3. Mazafer
    10
    457
  4. Mark Harvey
    29
    1,599
  5. Catfish
    30
    1,397
