Help! Gas not working
Discussion in 'Motorhome Chat' started by Piltonian, Feb 9, 2013.
  1. Piltonian
    Piltonian Read Only Funster
    Jan 29, 2013
    10
    6
    Devon
    I'm a newbie and I'm sure I'm missing something really obvious, but my gas appears to have stopped working for no apparent reason.
    I've got the Gaslow system fitted to my van. I've had a couple of nights camping out, everything's worked fine - most recently Thursday night, cooker, fridge, heater all working fine. I'm now staying with friends and just wanted to check I'd got the valve on top of the Gaslow bottle in the right place (having turned it off and on a few times with driving and stopping I'm not sure if it's ended up in the right place) so I turned a gas hob on briefly to check gas was coming out. No gas came through, so I turned the valve the other way. Still no gas came out. I've tried it back and forth, there's definitely no gas coming out of the hob.
    What might I be missing?
    I've never touched any other valves on the Gaslow system, and the cut off valves for the cooker etc are all in their correct places. Electricity is fine, leisure batteries are fully charged, temperature here is about 4C at the moment.
    I'm camping again tomorrow night, does anyone know what might be worng and how I might get the gas back by then?
    Thanks in advance - any help gratefully received.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,903
    17,577
    YO11 2BD
    may be a stupid question but you do have gas in the bottles dont you ?
  3. canopus
    canopus Funster Life Member
    Nov 27, 2010
    3,111
    3,482
    Lincolnshire
    Are both bottles turned on? Bottle 2 is the reserve normally :thumb:
  4. Piltonian
    Jan 29, 2013
    10
    6
    Devon
    Thanks both! There are two 11kg Gaslow bottles which I filled with exactly 45 litres of LPG, I've only used the van for two nights so far, and the indicator is showing that one bottle is full, the other nearly so.
    So far I've been using it with the first bottle turned on, the second turned off, and it had been working fine like that, but now is not. I'll go and try with them both turned on simultaneously now and report back if that makes a difference.
  5. Piltonian
    Jan 29, 2013
    10
    6
    Devon
    Right, just tested that. Opening the second bottle made no difference, but this time spotted something I should have seen before, a button on the bottom of a further valve, which seems to be a trip switch. Pressing that up restored the supply.
    I do apologise for bothering people, I'm sure I should have known that already - but I'm very grateful that Funsters were on hand and kindly took the trouble to reply!
    • Like Like x 1
  6. canopus
    Nov 27, 2010
    3,111
    3,482
    Lincolnshire
    Sounds like you have Secumotion fitted. Both push button valves have to be purged plus there could be another on the regulator.
  7. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,328
    5,332
    East Sussex 01-580-881288
    Dont apologise as others may learn from your post:thumb:
    Peter
    • Like Like x 4
  8. Piltonian
    Jan 29, 2013
    10
    6
    Devon
    Thank you Peter.
    Canopus - after Googling Secumotion and peering into the gas compartment, you're right:thumb:. Useful to learn that... I'm wondering how many other random things about the operation of the van I've yet to discover!
  9. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,575
    7,152
    Plymouth
    Lots but that's the joy of owning a motor home random things sent to try us :BigGrin:
    • Like Like x 2
  10. Larby
    Larby Funster
    Jun 17, 2012
    1,716
    3,991
    North Essex
    When I went off in MH for first time it was to learn all about it.
    Found Fridge/Freezer didn't work on 240v. Manual stated there was a fuse, but where? Wiring diagram showed switched fused spur, kept looking.
    Then SHMBO suggested it may be in the little cupboard next to the F/F, there it was, which was low down and hidden by the contents.
    Then this MH won't hold fresh water, but I've put the bung back in the tank. Read manual again, "To drain heater, open valve near pump........., so if I close the valve??
    Then once no gas to hobs in a caravan, (but had worked earlier?) no gas I'm told, I change for new one, no gas I'm told, but heater and fridge are working I protest, then she realises glass hob cover not fully back and sensitive safety valve has cut off supply. I don't say a word (I want my dinner and 40 years of marriage has taught me to keep it zipped and nod).
    But it was my fault anyway ! ! as caravan should be perfectly level she said.
    • Like Like x 1
